Wrecked My del sol, couple of ?'s
long story short , my friend drove my 95 d16z6 del sol into a tree. The engine is fine.
I have access to getting an automatic 1993 civic coupe with a bad motor.
I did a search , and looked through a couple of threads on doing the automatic to manual conversion. I still came up with a couple of questions.
Will the del sol shift linkage work for this? (Not sure if they are the same size as the civic coupe's)
Basically is everything i need for the conversion, available from the del sol?
THanks,
THanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srehtorblos »</TD></TR><TR><TD CLASS="quote">the del sol shift linkage will absolutely NOT fit. the del sol has its own shift linkages. i believe they are longer than the civics and integras. btw, sorry for your loss. have you seen the del sol thread?? in the APC forum??</TD></TR></TABLE>
No i havent. what is the APC forum?
Darn , Im looking for a regular civic linkage which i presume would work? Anything else you can think of? BTW thanks for your help .. i need to get a working car asap... if you need any parts off my sol let me know
powerline707
Jun 16, 2011 01:41 PM
