'01 civic (em2) gauge cluster led question
so i've searched a few different sites and haven't found anything definite. i'm trying to find 2 things. 1.) a good site that is reputable for selling high quality led's, and 2.) what size led i'd need to replace the 11 bulbs in the back of my friend's 01 civic cluster.
we already took the cluster apart and removed the red backing from the gauges so now they shine the color of the bulbs now just need to know which size to get.
Thanks in advance,
Ben
Thanks in advance,
Ben
http://www.oznium.com sells quality LEDs
and there's a DIY at http://www.hondacivicforum.com...33337
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Likuid »</TD></TR><TR><TD CLASS="quote">http://www.oznium.com sells quality LEDs
and there's a DIY at http://www.hondacivicforum.com...33337</TD></TR></TABLE>
that writeup is for 96-00 cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Likuid »</TD></TR><TR><TD CLASS="quote">My apoligies but you still got your LED site that you asked for.</TD></TR></TABLE>
yes, thank you for that
forgot to put that in my other post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">just go to the dealer... brand new oem</TD></TR></TABLE>
you're an idiot. there's nothing wrong with the lights in there, he just wants led's. if you have no info i need, stay the expletive out of the thread. thanks
bump for 01 gauge cluster led replacement sizing and no side bs
Thanks
Thanks
I have not replaced my bulbs for stuff like the turn signals and ebrake light and those things, but I have replaced my bulbs for the gauge faces and needles. The gauge/needle bulbs are different sizes than the turn signal/warning bulbs.
The size required are #74 LEDs, or T1.5 Instrument bulbs. They can be purchased from http://www.superbrightleds.com...xt=50
I do not know the size of the the turn signal bulbs.
Look for the T1.5 Instrument bulb on that page. Pick your colour, order, and install. Very easy. You will need somewhere between 8 and 14 bulbs depending on your year, model, and country the car was sold in. I've seen some take 12, mine only took 8.
To Install:
Remove your gauge cluster.
Look at the back of it, you will see the bulbs of the quarter twist in variety.
Remove them. NOTE: If you have an auto tranny, i dont think you can safely remove the lights that illuminate your gear selection. I dont know where I heard this but i seem to remember someone saying something about that.
Install the new LED bulbs.
Plug your gauge cluster back in, and make sure all lights are illuminated.
Since LEDs have a positive and negative side, if the bulb isnt lighting up, remove it, rotate it 180 degrees, and reinstall it.
Reinstall gauge cluster.
This should take about 15 minutes to do, as there is no soldering or anything.
Good luck.
Modified by bioweapon at 11:49 AM 6/25/2007
To Install:
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bioweapon »</TD></TR><TR><TD CLASS="quote">The size required are #74 LEDs, or T1.5 Instrument bulbs. They can be purchased from http://www.superbrightleds.com...xt=50</TD></TR></TABLE>
thank you sir, that's what i needed
maskedSONY
Dec 6, 2004 03:45 PM
ANGELIQUE
Mar 25, 2004 02:05 PM
