sooo i got my h22 running today
so..in my crx i got the h22 going. i took it out on a semi main street 1st thru 3rd pull back into my garage and start it up again... and my timing belt let loose...so...od u think my valves are bent?? and now...should i switch to a manual timing belt tentioner?? instead of the hydro one? also this was the first past on my motor. ive put 3 miles on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang »</TD></TR><TR><TD CLASS="quote">yeha but i gotta get tension back on the timing belt again....</TD></TR></TABLE>
...what are you waiting for?
my sister blew the timing belt on a sohc accelerating on an on-ramp. motor turn out to be perfectly fine.
