out of alignment after 91 si rear disc swap.
Old Jun 24, 2007 | 06:50 PM
msinsky14's Avatar
Default out of alignment after 91 si rear disc swap.
my car will not drive straight unless the steering wheel is turned 1/4 to the right after i installed a 91 si rear trailing arm complete swap. i reused the lca and did not remove the toe bolt. i did however reuse the 91 si uca because it had fairly new bushings.
so what would cause the alignment to be off, or is that normal after a swap?
Old Jun 24, 2007 | 06:55 PM
abnaasefmb's Avatar
Default Re: out of alignment after 91 si rear disc swap. (msinsky14)
get it aligned and go from there.
Old Jun 24, 2007 | 07:05 PM
msinsky14's Avatar
Default Re: out of alignment after 91 si rear disc swap. (abnaasefmb)
okay, i just spent a lot of money and i dont want to have to pay 80 bucks for an alignment if i dont have to
Old Jun 24, 2007 | 07:13 PM
99teggsr's Avatar
your should get an alignment anytime major suspension work is done. Heres a good article I just found from cspeedracing
http://www.c-speedracing.com/h...t.php
Old Jun 24, 2007 | 07:20 PM
powerpro_69's Avatar
Default Re: out of alignment after 91 si rear disc swap. (99teggsr)
yes anytime u change your height or anything on your suspension u need to get it alignment
Old Jun 25, 2007 | 03:08 PM
msinsky14's Avatar
Default Re: out of alignment after 91 si rear disc swap. (powerpro_69)
ok will do, thanks peeps
Old Jun 25, 2007 | 04:39 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">okay, i just spent a lot of money and i dont want to have to pay 80 bucks for an alignment if i dont have to</TD></TR></TABLE>
yes, you HAVE to.
its not an option.
Old Jun 25, 2007 | 07:54 PM
nickrps's Avatar
Default Re: out of alignment after 91 si rear disc swap. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
yes, you HAVE to.
its not an option.
Ditto.
When I installed my rear discs I had to have the car aligned. When I removed them to change bushings, I had to have the car aligned again. That's just how it goes. When you bolt them back on, your toe will most likely be out of wack. $80 is a small price to pay to fix it.
Old Jun 25, 2007 | 07:56 PM
jdmpnoy89's Avatar
Default Re: out of alignment after 91 si rear disc swap. (nickrps)
yah you pretty much have to get a alignment, since they unbolted your toe adjustor arms
Old Jun 25, 2007 | 09:04 PM
lessonsinspeed's Avatar
If you're planning on doing a lot of work over a short period of time which involves unbolting any or all of the suspension, try to find a shop that gives you a warranty or something along the lines of "free alignments for a year after the first." Saved me a lot of money when I was doing a lot of work on my suspension.
Old Jun 25, 2007 | 09:42 PM
Nisif's Avatar
Default Re: (lessonsinspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lessonsinspeed &raquo;</TD></TR><TR><TD CLASS="quote">If you're planning on doing a lot of work over a short period of time which involves unbolting any or all of the suspension, try to find a shop that gives you a warranty or something along the lines of "free alignments for a year after the first." Saved me a lot of money when I was doing a lot of work on my suspension.</TD></TR></TABLE>
Most Firestone dealers offer lifetime alignments. I spent $150 for it through a local ExpertTire store in my area. It pays for itself if you plan to keep your car for a while and plan to change the suspension setup. I did it solely because I'm awaiting the install of my DA front and rear brake setup.
Old Jun 26, 2007 | 04:23 AM
MiloReaper87's Avatar
U must of not align the bottom right this is pretty rare to hear after a rear disk brakes swap but like every other OEM component there not the best after years of abuse and weather chewin em so expect to end up buyin some stiffness!!!
Old Jun 27, 2007 | 07:29 PM
msinsky14's Avatar
Default Re: (MiloReaper87)
i dont kno, the swap went perfectly and i realized the steering wheel was off because the last time it got aligned was after i rebuilt the steering rack and i had full tread on my drivers side tire, and none on my pass. side tire(in front). the shop i got it aligned at said thats why. it drives very straight, maybe a little off.
otherwise, its not the disc swap, its the fact i just put new tires on the same time i did the swap. i was too lazy before
Loserjerk57
Jul 19, 2018 05:53 PM
15psi of fun
Jan 15, 2010 09:30 AM
ceezo70
Feb 15, 2009 09:04 PM
wizzards581
13
May 16, 2004 08:11 AM
thrill91si
Aug 20, 2003 03:02 PM
