Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Where to find 01' LX Swaybar?
Old Jun 24, 2007 | 06:15 PM
TailZ's Avatar
Default Where to find 01' LX Swaybar?
Hey guys need your help on looking for an oem 01' lx swaybar.
Know any sites that sell em'? How much do you think the dealer charges?
I'll be purchasing that and a rsx rsb after my drop.
PS: I don't use paypal..
Old Jun 24, 2007 | 07:54 PM
OSK Automotive's Avatar
Default Re: Where to find 01' LX Swaybar? (TailZ)
Go here and look it up (I'm too lazy right now)
http://www.hondaautomotivepart...h.jsp
Old Jun 24, 2007 | 08:24 PM
TailZ's Avatar
Default Re: Where to find 01' LX Swaybar? (OSK Automotive)
thanks for the site!
i found the rsb but still looking for fsb as of right now..
Old Jun 25, 2007 | 01:17 AM
TailZ's Avatar
Default Re: Where to find 01' LX Swaybar? (hondalvr222)
no luck on ebay..
plus i don't use paypal.
Old Jun 25, 2007 | 02:29 AM
Youngcity's Avatar
y would you have a <3 next to bodykits
Old Jun 25, 2007 | 05:50 AM
Default Re: Where to find 01' LX Swaybar? (Youngcity)
http://www.hondaautomotivepart...UCKLE
It's #5
Old Jun 25, 2007 | 12:47 PM
TailZ's Avatar
thanks osk!
mmm 38 bucks sounds good!
so I need the bushings also right?
just making sure.
EDIT: Why is it that they put a much beefier sway bar(25.4mm?) into 01' LX and and in
the 03' EX all I got are twigs (15mm?) sway bars?
Old Jun 25, 2007 | 12:54 PM
fventura03's Avatar
why would you spend $38 + shipping on a stock sway bar when you can have a used rsx sway bar for $50 shipped (clubrsx.com)
people throw away the stock sway bars, they aren't worth anything. if your car didn't come with a sway bar already, you need to buy the adapter kit from progress.
btw, you should probably get paypal, that's what 90% of people who sell stuff on forums use. that or look for someone that will accept a check/money order.
Old Jun 25, 2007 | 01:04 PM
TailZ's Avatar
Default Re: (fventura03)
because my fsb is like 15mm and the rsb is I think 12mm not so sure. but i'm hopefully
getting the fsb from a 01' LX being that it's 25.4mm and a RSX rsb 19/22mm. I did a
little research and for the street this is suppose to be a great setup but for the track
it wouldn't because of understeer. but if you have coilovers you can tune to reduce
understeer. correct if I'm wrong not a 100% sure
Old Jun 25, 2007 | 02:33 PM
WhiteOnRice's Avatar
That's what an alignment is for
Old Jun 25, 2007 | 04:37 PM
Default Re: (TailZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TailZ &raquo;</TD></TR><TR><TD CLASS="quote">because my fsb is like 15mm and the rsb is I think 12mm not so sure. but i'm hopefully
understeer. correct if I'm wrong not a 100% sure</TD></TR></TABLE>
^correct and props for doing the research. WhiteOnRice is also right about the alignment. From my personal experience going from a 24mm front bar to a 15mm front bar is a lot better.
Old Jun 25, 2007 | 06:18 PM
Vantage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TailZ &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the site!
i found the rsb but still looking for fsb as of right now..</TD></TR></TABLE>
Incorrect, u cannot find an 01 LX's rear sway bar as no 01 LX's came with them stock.
If u want to run a rear sway bar on an 01 LX, u will need to buy a progress rear sway adapter kit.
Old Jun 25, 2007 | 08:17 PM
TailZ's Avatar
Default Re: Where to find 01' LX Swaybar? (Vantage)
yeah I got it mixed up I put in 03 EX.
Old Jun 26, 2007 | 10:27 PM
BojeEM2's Avatar
there is no need for any thing bigger then 22mm........it is just overkill........make sure to get some beefy end links because ours are really wimpy........and make sure to get a sub frame brace....that sway bar needs something to hold on too..........
Old Jun 27, 2007 | 12:01 AM
Jstans84's Avatar
Hey do any LX EM2's have a stock rsb?
Old Jun 27, 2007 | 12:28 AM
TailZ's Avatar
For the 01' lx fsb would I need to purchase the endlinks also? or are the endlinks the same as a 03' ex?
Old Jun 27, 2007 | 05:13 AM
Default Re: (Jstans84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstans84 &raquo;</TD></TR><TR><TD CLASS="quote">Hey do any LX EM2's have a stock rsb?</TD></TR></TABLE>
Depends on the year. Check this out http://www.geocities.com/bellz....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TailZ &raquo;</TD></TR><TR><TD CLASS="quote">For the 01' lx fsb would I need to purchase the endlinks also? or are the endlinks the same as a 03' ex?</TD></TR></TABLE>
Endlinks are the same.
Old Jun 27, 2007 | 05:16 AM
Vantage's Avatar
only the 01 LX didnt come with a rear sway.
02+ did.
Old Jun 27, 2007 | 05:17 PM
Jstans84's Avatar
Awesome, thank you sir.
CivicRyDa
May 4, 2011 06:17 PM
picos
Jun 10, 2006 05:24 PM
Dilly
Audio / Security / Video
Feb 24, 2006 02:51 PM
JDM_wanna_Be
Jan 26, 2006 04:09 PM
MarkZeroNine
Jan 28, 2005 11:45 AM
