Searched...no one has desire for this so no old posts
Old Jun 24, 2007 | 02:37 PM
HondaHeddie's Avatar
Default Searched...no one has desire for this so no old posts
1)
I need a rear wiper arm for my 91crx
I cannot find a junker with an oem rex arm
I have tried 1st gen and 2nd gen teg but they are too big.
The splined cone is smaller on the rex than on the teg so the arm from a teg will never engage the shaft and ends up flopping around when I try one.
is there anything other than a gen2 rex that has this wiper arm on it
does anyone have an arm?
I know alot of us are into pulling the whole wiper system.
Honda wants 50-bucks and I have more important things to spend that on currently.
if you are within a couple hundred miles of me I can come get it(at 52+mpg I dont mind the drive at all)
If not I will send you a call tag to ship it at my cost
please help wipe this problem off my table
2)
my rear washer fluid nozzel squirts like a broken watergun. is that what it is supposed to do? it barely makes it 25% down the window.
if it is somehow widened is it easy to replace?
or is there a way to get all my nozzels to spray, instead of squirt?(hi-pressure washer pumps or something)
Old Jun 24, 2007 | 03:45 PM
altoid's Avatar
Default Re: Searched...no one has desire for this so no old posts (HondaHeddie)
88-91 wagovan. check them out. they came in 2wd and 4wd versions, shouldn't matter which one though. I woudl be surprised if honda used a different motor/blade combo for the wagon.
as for the nozzle, just soak it in some vinegar or lemon juice (vinegar is cheaper) for an hour or so it'll loosen up the hard water deposits and you should have a good nozzle again.
Old Jun 24, 2007 | 03:49 PM
altoid's Avatar
Default Re: Searched...no one has desire for this so no old posts (altoid)
omfg, how you getting 52 mpg? I just bought a 90 rex dx, best I've done so far is 39.3. Wheres the sweet spot on the rpm band?
Old Jun 24, 2007 | 03:54 PM
4g hatch's Avatar
probably a hf. 8 valve 1.5 thats geared high as hell
Old Jun 24, 2007 | 07:38 PM
druciferrr's Avatar
ive got a USDM wiper arm i dont need
HondaHeddie
Mar 14, 2008 12:57 PM
ecl-ricochet
Jul 9, 2006 08:31 PM
bryan305
Sep 8, 2002 03:54 PM
Aphrodavid
Jul 28, 2002 10:29 AM
