Can bad axles cause vibration upon braking?
Old Jun 24, 2007 | 09:41 AM
DougNuts's Avatar
Default Can bad axles cause vibration upon braking?
I have replaced the brakes on my wifes car 3 or 4 times in the last 3 years. Most recently I put on Brembo rotors and Hawk HP pads. She still has a vibration when braking. The harder you press the pedal, the worse it vibrates.
I jacked the car up and put it in drive to watch the brake rotors. They don't appear to be warped at all. However, the CV axles do move around a bit as they spin. Could they be the culprit of our brake shimmy? The car is a 99 Ex auto with 150K miles and original axles.
Old Jun 24, 2007 | 10:17 AM
jz98ctr's Avatar
Default Re: Can bad axles cause vibration upon braking? (DougNuts)
it IS possible but you'd probably also have the shakes upon braking, accelerating, and turning so it might not be as well. see if there is any other situation that it occurs in.
um...this might be a dumb question but do you have ABS on that car?
Old Jun 24, 2007 | 10:18 AM
john666's Avatar
yes
i remember my friend had a problem simaliar to yours(vibration). he checked by jacking the car up and putting it on bricks and stepping on the gas while another friend looked at the axel in movement.. of course that can be dangerous if you dont put something so the car doesnt fall on you so keep that in mind if you plan to do that
Old Jun 24, 2007 | 12:39 PM
DougNuts's Avatar
Default Re: Can bad axles cause vibration upon braking? (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">yes
i remember my friend had a problem simaliar to yours(vibration). he checked by jacking the car up and putting it on bricks and stepping on the gas while another friend looked at the axel in movement.. of course that can be dangerous if you dont put something so the car doesnt fall on you so keep that in mind if you plan to do that</TD></TR></TABLE>
The million dollar question, did it happen only when braking? I took it out and got on it a bit, but I got no vibration upon acceleration.
Old Jun 24, 2007 | 12:40 PM
DougNuts's Avatar
Default Re: Can bad axles cause vibration upon braking? (jz98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">um...this might be a dumb question but do you have ABS on that car?</TD></TR></TABLE>
Yes, I think so.
SoullessJapaneseMachine
Aug 4, 2007 02:20 PM
margaflow
Acura NSX
11
Apr 19, 2005 10:16 AM
cliff666
10
Dec 19, 2003 02:18 PM
DanielLaruso
29
May 22, 2003 11:27 AM
Type_gsR
Mar 9, 2003 07:51 PM
