WIRING NIGHTMARE
Old Jun 24, 2007 | 09:05 AM
joeekrub's Avatar
Default WIRING NIGHTMARE
Ok, so I put the new engine in my type r (other engine blown)... Its a b20b/gsr vtec head.... Question is I am putting in the wiring harness from the type r today and was wondering if there is a better wiring diagram than in the Haynes... All I need is the engine wiring......Help would be appreciated Thanks
Old Jun 24, 2007 | 09:35 AM
94rs-turbo's Avatar
not sure on the diagram but that harness should plug strait into your setup
Old Jun 24, 2007 | 09:48 AM
neo_'s Avatar
Default Re: (94rs-turbo)
Are you using the appropriate ODB2 Distributor and Alternator?
Old Jun 24, 2007 | 02:50 PM
joeekrub's Avatar
Default Re: (neo_)
im using the stuff that came off the 97 type r.......all is the same except for intake manifold, head and block ...... vtec and everything is same
Old Jun 24, 2007 | 02:51 PM
joeekrub's Avatar
Default Re: (joeekrub)
and for some reason when I bring the harness underneath the manifold, the connections for the injectors arent long enough.... is that a common problem? or is the way im bringing them up wrong?
Old Jun 24, 2007 | 03:10 PM
94rs-turbo's Avatar
so your using the gsr intake manifold?
Old Jun 24, 2007 | 06:39 PM
joeekrub's Avatar
ya using the gsr intake, the type r wont fit.... got the wires figured out thanks...... but is the gsr intake really that bad? do I need to get the skunk2?
Old Jun 24, 2007 | 09:56 PM
prelude_93vtec's Avatar
Default Re: WIRING NIGHTMARE (joeekrub)
google
bdlongGSR
Apr 13, 2011 01:39 PM
95Sol99civic
Dec 22, 2009 06:10 PM
Shady Hills
Feb 2, 2003 08:22 PM
