Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
'06 Si...cracked oil pan, or flywheel cover...
Old Jun 24, 2007 | 08:56 AM
mikseries's Avatar
Default '06 Si...cracked oil pan, or flywheel cover...
So, I'm jacking my car up to change my oil (with a wood block because my cheap @$$ jack needs it). About 8 inches off the ground, the woodblock slips and the jack cracks this little area that looks like it's near where the transmission is bolted to the oil pan. But, there are no fluids leaking and the car is running fine. Can someone take a look at this image and tell me what the hell I've done to my car and how serious it is. Feel free to let the insults fly...I deserve it if I've F'd my car up.
Old Jun 24, 2007 | 08:59 AM
Type X's Avatar
Default Re: '06 Si...cracked oil pan, or flywheel cover... (mikseries)
ghetto fix = JB weld
Proper fix = Taking it to a mechanic to survey the damage BEFORE honda.
Ask someone if you throw him 20 dollars to just look it over.
While nothing is leaking NOW, Cracks + super high temps = not a good combo.
Old Jun 24, 2007 | 09:42 AM
mikseries's Avatar
Default Re: '06 Si...cracked oil pan, or flywheel cover... (Type X)
yep, it already started leaking...
any idea how much this is gonna cost me (at honda or otherwise)?
Old Jun 24, 2007 | 09:44 AM
24boosted's Avatar
At least it wasn't your face that it fell on. Let this be a lesson to others, get a quality jack and jack stands. Check pricing for a new oil pan then go from there.
Old Jun 24, 2007 | 09:52 AM
lsvtec101's Avatar
Default Re: '06 Si...cracked oil pan, or flywheel cover... (24boosted)
it looks like you just need a new oil pan 122.76 from http://www.hondaautomotiveparts.com
Old Jun 24, 2007 | 11:28 AM
faster Type R's Avatar
what was your jack doing around the oil pan
Old Jun 24, 2007 | 12:55 PM
civic1234's Avatar
Default Re: (faster Type R)
man on man... thats a bummer, at least you weren't under the car... always jack the car up at the appropriate spots... its usually the same area on every car ( right behind the front wheels or on the frame near the engine) the owners manual is there for a reason... read it man!
the oil pan shouldnt cost much.. cross your fingers.
Old Jun 24, 2007 | 03:55 PM
IGotNoSwap's Avatar
Default Re: (civic1234)
oil pan, gasket, and hondabond.
i dented up one on my crx.
Old Jun 24, 2007 | 05:48 PM
DSEA2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faster Type R &raquo;</TD></TR><TR><TD CLASS="quote">what was your jack doing around the oil pan</TD></TR></TABLE>
Old Jun 24, 2007 | 06:57 PM
yuning83's Avatar
wow that sucks, please tell me this wasn't your spare tire jack. Because I'm need to use that tomorrow on my car...
Old Jun 24, 2007 | 07:16 PM
E-Money's Avatar
Default Re: '06 Si...cracked oil pan, or flywheel cover... (yuning83)
better off using the jacking points next time
Old Jun 24, 2007 | 07:37 PM
kroze's Avatar
Default Re: '06 Si...cracked oil pan, or flywheel cover... (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">better off using the jacking points next time</TD></TR></TABLE>
people who don't know how to change oil should pay $30 and let the pros do it. you end up doing more damage than good.
Old Jun 24, 2007 | 08:24 PM
NTX
Guest
Posts: n/a
Default Re: '06 Si...cracked oil pan, or flywheel cover... (kroze)
damn
Old Jun 25, 2007 | 07:28 AM
mikseries's Avatar
i was at the jack point. but my jack alone won't get the car high enough off the ground to get the jack stands behind the front tires. So, i have a wood block as a filler between the jack and the jack point. The wood block slipped and the car fell onto the jack that was still locked in place. Jack vs Oil Pan...Jack won.
Old Jun 25, 2007 | 07:40 AM
TRE_'s Avatar
Default Re: (mikseries)
I would just take the car into the dealership and tell them its leaking oil/fluid.
Old Jun 25, 2007 | 07:41 AM
Echo7847's Avatar
new pan + ultra flange 2 sealant (gasketless pan)
expect to pay around 160ish @ the dealer + parts to replace.
Old Jun 25, 2007 | 09:51 AM
IT GUY's Avatar
Default Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">it looks like you just need a new oil pan 122.76 from http://www.hondaautomotiveparts.com</TD></TR></TABLE>
and use Hondabond for $15 (not ultra flange 2)
Old Jun 25, 2007 | 11:51 AM
E-Money's Avatar
Default Re: (IT GUY)
scissor jack
lochenjons
15
Dec 27, 2011 05:42 PM
dth0ng69
Aug 12, 2009 08:11 PM
ImPuLsIvE
Oct 29, 2008 06:44 AM
lude98SH
Oct 6, 2008 03:31 PM
