rear disc swap pin and snap ring for ebrake cable
one side of the swap i ordered did not come with a pin and snapring for the ebrake cable to caliper bracket. its a 91 crx si rear disc swap. does lowes or home depot sell the same type of pin and snap ring? i need the swap done by this afternoon and dealerships arent open.
One of mine was rusted so I had to grind it off, I just used the right size bolt and locknut. It has been fine for years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">one side of the swap i ordered did not come with a pin and snapring for the ebrake cable to caliper bracket. its a 91 crx si rear disc swap. does lowes or home depot sell the same type of pin and snap ring? i need the swap done by this afternoon and dealerships arent open. </TD></TR></TABLE>
I can't quite think of the part your refereing to but I do know you won't find stuff like that anywhere but the dealer or junk yard. If you have a pic of the part that would really help, if it's the part I think it is you will need to hold out for a junkyyard or dealer............can you post a pic or 2?
tekstyle
Dec 10, 2007 01:40 AM
