some impt things to do when installin pro1s in an h22?
Old Jun 24, 2007 | 06:35 AM
snzh22's Avatar
Default some impt things to do when installin pro1s in an h22?
what are some things to make sure that i check for or do when installing skunk2 pro 1 cams in my usdm h22?
things that will be installed are the cams, cam gears, springs and retainers, manual tensioner conversion, cam seals, the seal on the opposite side of the gears (i think its called the rubber cap/cam plug), and a valve cover gasket kit. stock valves, rockers, keeps, ect.
Old Jun 24, 2007 | 07:24 AM
snzh22's Avatar
Default Re: some impt things to do when installin pro1s in an h22? (snzh22)
also to break in im gonna be holding the engine at 2k rpm for 5 min. and im not gonna be able to get it tuned for a week or so...i kno i cant step on it but i can drive it around, like not gettin it more than 1/2 throttle and i wont go over 4k rpm. anything else i should keep in mind?
Old Jun 24, 2007 | 07:38 AM
alterdcreations's Avatar
just check for leaks. hook up a laptop and drive the car. take it easy until the car reaches normal operating temps beat on it
Old Jun 24, 2007 | 09:37 AM
snzh22's Avatar
Default Re: some impt things to do when installin pro1s in an h22? (alterdcreations)
i was told i shouldnt beat on it until i am or have already gotten it tuned
also right now there is a little bit of oil buildin up on the left side of the head, behind the distributor cap. i was told it could be the "rubber cap." that problem should be resolved when i replace that piece.
Old Jun 24, 2007 | 11:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">just check for leaks. hook up a laptop and drive the car. take it easy until the car reaches normal operating temps beat on it
Old Jun 24, 2007 | 11:23 AM
snzh22's Avatar
can i drive it around w/o going to 1/2 throttle or 4k before it gets tuned?
Old Jun 24, 2007 | 11:30 AM
un hook vtec and drive in safe mode.
Old Jun 24, 2007 | 11:39 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snzh22 &raquo;</TD></TR><TR><TD CLASS="quote">can i drive it around w/o going to 1/2 throttle or 4k before it gets tuned? </TD></TR></TABLE>
your prolly gonna do it anyway, so just do it.
Old Jun 24, 2007 | 01:58 PM
snzh22's Avatar
Default Re: some impt things to do when installin pro1s in an h22? (98vtec)
well i might get the cams in before i get the header in. i wanna have both in before i tune it. it also depends on my friends schedule and how that works out with the tuners schedule
Old Jun 24, 2007 | 07:33 PM
mgags7's Avatar
theres not a whole lot to that job, if you need help just check my writeup, its in the lude forum faq.
Old Jun 24, 2007 | 07:43 PM
snzh22's Avatar
Default Re: (mgags7)
thanks for the support guys...but yea i have no mechanic experience AT ALL. so im gonna be paying someone to do most of the work with my help to the best of my ability. after i get it street tuned, soon after i will get it to the dyno just to see how much power it makes. i should be getting it to the same dyno that i previously dynod 178 at in, in 3rd gear with an f22 tranny
Old Jun 24, 2007 | 07:45 PM
snzh22's Avatar
Default Re: (snzh22)
should i have a valve adjustment job done as well during the install?
Old Jun 24, 2007 | 08:14 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snzh22 &raquo;</TD></TR><TR><TD CLASS="quote">should i have a valve adjustment job done as well during the install?</TD></TR></TABLE>
That's pretty much mandatory.
Old Jun 25, 2007 | 09:56 AM
h22crxpwr's Avatar
installing new cams needs a definite valve adjustment, unless you want bent valves.. hopefully whoever is doing your install will (should) know these things. since you stated that someone else will be doing all the work. good luck!
v99h22
27
Aug 31, 2013 05:36 PM
rrace002
93
Oct 25, 2012 04:37 PM
eg_h22
Jul 21, 2009 12:24 AM
carlitosway12345678
Oct 3, 2008 09:55 PM
CBR
Apr 29, 2004 03:07 PM
