car acts stupid while driving
Old Jun 24, 2007 | 02:19 AM
zenon8890's Avatar
Default car acts stupid while driving
my car acts stupid after i drive it for 5 min, when i start it its like a champ, but when i'm cruising slowly in it suddnly its starts to bog like there's no fuel in it, or fuel is not reaching the engine, i checked the fuel pressure gauge, its like 15psi and it should be 35, i'm running a turbo d15b vtec, i thought the fuel pump (walbro255hp) is not getting enough power so i changed the whole wiring for a better quality wires, ran great yesterday, but today it started again, but when i turn off the car and start it again, it works fine like nothing happen, but just wait five minutes of driving at normal speed limit it does the same thing again.
whats the problem?! fuel filter maybe?! timing?!
Old Jun 24, 2007 | 04:25 AM
vdawg559's Avatar
vaccum leaks? spark plugS and wire>? check dem out.
Old Jun 24, 2007 | 07:02 AM
zenon8890's Avatar
new spark plugs, no vacume leak, i mentioned that when i start the car and drive it, it does nothing, it just do that when i drive at loew rpms
Old Jun 24, 2007 | 10:07 AM
jlicrx's Avatar
Default Re: car acts stupid while driving (zenon8890)
we have seen the same problem on several cars with the walbro pump - appears the filter screen on the end of the pump collapses and won't let the pump pick-up fuel - probably were fake "Walbro" pumps and the filter didn't fit like the one on the OEM pump
Modified by jlicrx at 12:31 PM 6/24/2007
Old Jun 24, 2007 | 02:55 PM
zenon8890's Avatar
Default Re: car acts stupid while driving (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">appears the filter screen on the end of the pump collapses and won't let the pump pick-up fuel</TD></TR></TABLE>
but if its true it should act funny all the time, btu it runs fine once i start the car, or when i'm driving in boost
Old Jun 24, 2007 | 05:05 PM
Budget Ballin's Avatar
Ive seen this problem on two crx's this past week. Both were the distributor. Try changing that.
Old Jun 24, 2007 | 11:10 PM
zenon8890's Avatar
Default Re: (Budget Ballin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget Ballin &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen this problem on two crx's this past week. Both were the distributor. Try changing that.</TD></TR></TABLE>
i had the same problem before with the dizzy, but i'm not in limp mode and i dont have code 4, pressure gauge keep falling from 35psi to 15psi, something wrong with the pump or wiring, or cuz of the heat
PuFFIN420
Jun 10, 2014 08:38 PM
HondaPartsHero
Feb 6, 2011 01:55 PM
charliewolf_0
Feb 2, 2009 10:50 AM
J-SpecRacing
Mar 9, 2008 03:58 PM
ABTDer
Oct 30, 2003 06:30 PM
