which motor is which
Old Jun 23, 2007 | 05:53 PM
1991hb's Avatar
Default which motor is which
I know this is a pretty stupid question but I don't care. Which B16's are OBD0, which are OBD1, and which are OBD2. What cars did they come out of? I want a b16 but I want one that is OBD1. Thanks
Old Jun 23, 2007 | 08:29 PM
Crx Jimmy's Avatar
Default Re: which motor is which (1991hb)
all the b16's can be converted to obd1 very easy the only difference on the motor itself are the injectors which you probably will still want to rub obd0 injectors on anyway so when you convert you can keep the resistor box and not have to mess with it and solder it. If you want a obd1 B16 for some other reason they came in JDM 92-95 integra's, delsol to 95, and in 92-95 civics. Anything newer than 95 is obd2
Old Jun 23, 2007 | 08:32 PM
Under Con. CrX's Avatar
Default Re: which motor is which (Crx Jimmy)
B16a=OBDO
B16a2=OBD1
B16B=OBD2
Old Jun 23, 2007 | 08:37 PM
Crx Jimmy's Avatar
Default Re: which motor is which (Under Con. CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">B16a=OBDO
B16a2=OBD1
B16B=OBD2
thats retarded it doesnt make any sense^^. All jdm b16's are b16a regardless of obd designation. There are obd2 b16a's as well. And a b16a2 was a us motor. ITs really not that helpful more confusing . To the OP disregard that guy
Old Jun 23, 2007 | 08:42 PM
.Grimace's Avatar
footwork mastery
B16a2=OBD1
B16B=OBD2
wow.... no
Old Jun 23, 2007 | 11:06 PM
1991hb's Avatar
Thanks CRX Jimmy
Old Jun 23, 2007 | 11:56 PM
~sp33~'s Avatar
EFB055
Default Re: which motor is which (Gremice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gremice &raquo;</TD></TR><TR><TD CLASS="quote">
wow.... no </TD></TR></TABLE>
Shutdown lol.
Old Jun 24, 2007 | 12:01 AM
crx_si-r's Avatar
Default Re: which motor is which (~sp33~)
i coulda sworn it was
b16a3-----obd1/2a 93-97 del sol vtec model
b16a2-----obd2b 99-00 civic si
for us spec b16's
or am i wrong?
Old Jun 24, 2007 | 12:13 AM
HonDelso's Avatar
US spec
B16a3 - 94-95 Del Sol Vtec P30 ecu (OBD1)
B16a2 - 96-97 Del Sol Vtec P2T ecu (OBD2a), 99-00 Si P2T(OBD2b)
JDM the only way you can tell is to check the castings. they designate the year.
Old Jun 24, 2007 | 12:40 AM
vdawg559's Avatar
what the freak. deres a 97 del so???? never knew that.. how does that even look like...lmao
Old Jun 24, 2007 | 03:13 AM
HonDelso's Avatar
93-95 del sol have aux lights
96-97 del sol don't have aux lights
Old Jun 24, 2007 | 03:57 AM
vdawg559's Avatar
u know ur stuff. thumps up.
davidcrx89
Mar 5, 2005 01:11 PM
frankist
Dec 28, 2004 05:54 AM
Layziebtnh055
May 28, 2004 04:30 PM
Wes V
May 8, 2003 03:21 AM
