QUESTION I know alot of people are wondering
Old Jun 23, 2007 | 05:19 PM
DSRacing's Avatar
Default QUESTION I know alot of people are wondering
I have to question's that I would like some OPINIONS on.
1st. which is making more power a profab or the tri-y maybe even dyno sheet would help
2nd. Anyone try the blox proseries cams yet I think we all want to know what if any difference from skunk.
Old Jun 24, 2007 | 12:31 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: QUESTION I know alot of people are wondering (DSRacing)
The profab header is a copy of a tri-y header design... the best way to find out what kind of power it will make is to look at the original design it was copied from.
The blox cams are also copies of many original cam designs, the most common ones being Skunk. Again if you want to know how they'll perform, just look at what they're copied from. There's more than enough documented information on this site from people who have used them if you look for it.
Something you should keep in mind when buying copies is that fit, finish and durability are often issues as well as difficulty in tuning for other things. Technical support and warranty support are often difficult if not impossible to get as well...but hey, at least your saving a few bucks right?
Old Jun 24, 2007 | 01:52 PM
Scott_Tucker's Avatar
Default Re: QUESTION I know alot of people are wondering (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
Something you should keep in mind when buying copies is that fit, finish and durability are often issues as well as difficulty in tuning for other things. Technical support and warranty support are often difficult if not impossible to get as well...but hey, at least your saving a few bucks right? </TD></TR></TABLE>
The Blox cams are their own design but are now ground by Elgin Cams. They are ground from new stock cams so the metal quality is good. Elgin grinds some of the best cams in the world (quality wise) so having him grind them is a good thing. The website says they are CNC ground which is not true if all of their cams are in fact ground by Elgin. CNC grinding of a precise component like cams isn't always best idea quality wise. You can make more cams per hour with CNC equipment but hand grinding includes that human element of quality control throughout the entire process. Elgin did not design the cam profiles himself so whether or not it is a good design I don't know. Dema would not grind knock-off cams.
Old Jun 25, 2007 | 11:48 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: QUESTION I know alot of people are wondering (Scott_Tucker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker &raquo;</TD></TR><TR><TD CLASS="quote">
Dema would not grind knock-off cams.</TD></TR></TABLE>
So Blox "C" aren't Jun 3 copies.... The Blox P1 isn't a Skunk 2 pro 1 copy?
Blox doesn't copy??
Old Jun 25, 2007 | 12:00 PM
Blox doesn't copy?? </TD></TR></TABLE>
I should say Dema wouldn't knowingly grind copied cams. Like I said he is just doing the grinding but Blox supplied the eccentrics for the grinders. The Blox cams may have the same lift and duration as the other cams but that in no way means they are copied.
Old Jun 25, 2007 | 04:17 PM
lunatics209's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRacing &raquo;</TD></TR><TR><TD CLASS="quote">I have to question's that I would like some OPINIONS on.
2nd. Anyone try the blox proseries cams yet I think we all want to know what if any difference from skunk. </TD></TR></TABLE>
pro fab is a tri-Y. pro fab is a great header. fitment is good plus the power. well i did not do any dyno comparison but i did make 192 horse and 132 torque on an all stock ls-vtec.
Old Jul 19, 2007 | 06:34 PM
DSRacing's Avatar
just picked up some blox(proseries copy)pro2, i have some real skunk pro2's on the self compared it looks like an exact match.
Old Jul 20, 2007 | 12:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (DSRacing)
so you're saying you visually checked them and they look similar, or that you degreed both cams and found them to be exact? big difference....
Old Jul 21, 2007 | 12:00 AM
DSRacing's Avatar
to be honest i just looked but i need to kinda find out 4sure because pro2's are what i wanted pro3's are 2big plus bad luck with them
turbo boost
Feb 1, 2015 03:13 PM
Staypuff578
18
Dec 15, 2011 07:32 AM
99hondacura
Feb 16, 2007 01:19 PM
boostd ls
13
May 21, 2006 10:24 AM
slipage
Nov 1, 2005 05:49 PM
