Twin disc clutches pedal stops.
Old Jun 23, 2007 | 04:20 PM
94turboeg's Avatar
Default Twin disc clutches pedal stops.
How many twin disc clutches need pedal stops?
Old Jun 23, 2007 | 04:22 PM
Jared's Avatar
all the ones ive used
Old Jun 23, 2007 | 04:32 PM
Mikey3000's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">all the ones ive used</TD></TR></TABLE>
really? i'm not using one now with my competition. it engages pretty low. is there a sure-fire way to tell whether you need one or not?
Old Jun 23, 2007 | 04:40 PM
Jared's Avatar
Default Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">
really? i'm not using one now with my competition. it engages pretty low. is there a sure-fire way to tell whether you need one or not?</TD></TR></TABLE>
I didn't need anywhere near the full pedal throw with the cc twin.
Old Jun 23, 2007 | 05:41 PM
SpeedDreamz.com's Avatar
Default Re: (Jared)
The issue is that you dont need all the pedal throw to disengage the clutch so why waste the extra motion. I have used pedal stops on all the twins I have owned.
Old Jun 23, 2007 | 06:49 PM
BB6-213's Avatar
Anyone have pics of the setups?
Old Jun 23, 2007 | 06:53 PM
ykracing's Avatar
Default Re: (BB6-213)
EXEDY doesnt need one.
Old Jun 23, 2007 | 09:50 PM
BoOsTiN Dc2's Avatar
Default Re: (ykracing)
im curious on this too... my twin disc catches very low... do you guys put the pedal stop on the top or bottom?
Old Jun 23, 2007 | 09:57 PM
B18C1CYA's Avatar
Default Re: Twin disc clutches pedal stops. (94turboeg)
I tryed one on my CC twin , and it shifted ok driving around town , but when I took it past 7000 rpm , it would lock me out of gear , so I adjusted the rod on the clutch peddle all the way short , works for me
Old Jun 24, 2007 | 03:24 AM
Default Re: Twin disc clutches pedal stops. (B18C1CYA)
when would you know you need a pedal stop?
Old Jun 24, 2007 | 06:10 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ykracing &raquo;</TD></TR><TR><TD CLASS="quote">EXEDY doesnt need one.</TD></TR></TABLE>
Old Jun 24, 2007 | 06:20 AM
Turbo-charged's Avatar
i have been running the Exedy twin for over 2 years now with no pedal stop, making decent power, with out a single issue. however i just installed one for some "things" im trying.
Yoni, thanks for the help on the pedal stop we talked about...it actually worked very very well. completely adjustable too i think i can still shorten the pedal travel a little bit, but im pretty happy with where its at right now.
EXEDY
Old Jun 24, 2007 | 03:50 PM
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">
EXEDY </TD></TR></TABLE>
Didnt they outlaw slippers?
Old Jun 24, 2007 | 04:56 PM
ALL IMPORT's Avatar
Default Re: (SpeedDreamz.com)
whats the advantage.?
u dont have to waist usless throw?
i got exedy twin & it engages 1/4 way so thiers alot of usless pedal thier.
Old Jun 24, 2007 | 06:09 PM
fast2camciv's Avatar
anyone have pics or info on how they did it? i will be using a tilton twin disc on this build, its the first twin disc i have had experience with so please bare with me
Old Jun 24, 2007 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">
Didnt they outlaw slippers? </TD></TR></TABLE>
Old Jun 24, 2007 | 10:00 PM
s4yama's Avatar
Default Re: (BoOsTiN Dc2)
I was told by cc that it's better to have the clutch grab closer to the top and then adjust your pedal stop from there. So you can eleminate any excess travel so you can have a quicker shift. The idea is to not go over center on the pressure plate so you dont damage it.
Old Jun 25, 2007 | 12:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTiN Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">im curious on this too... my twin disc catches very low... do you guys put the pedal stop on the top or bottom?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTiN Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">when would you know you need a pedal stop?</TD></TR></TABLE>
no answers?
Old Jun 25, 2007 | 04:40 AM
DaveF's Avatar
you can test this by having the car up on jack stands, and slowly pushing the clutch pedal toward the floor until you can spin the tires(you will need 2 people for the task) then when it disenguages, you need about 1/8-1/4 of more pedal travel, any more than that, and you will damage the pressure plate.
Old Jun 25, 2007 | 05:04 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (dturbocivic)
I don't use one.
Old Jun 25, 2007 | 05:29 AM
SPOOLINmatt's Avatar
Default Re: (turbotypeR@SPEC)
an easy way to do this is with a bolt through the clutch start switch hole with a lock nut. I havnt had any issues with my CC twin without a stop.
Old Jun 25, 2007 | 06:07 AM
Jared's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">an easy way to do this is with a bolt through the clutch start switch hole with a lock nut. I havnt had any issues with my CC twin without a stop. </TD></TR></TABLE>
how do you guys get through tech with that?
Old Jun 25, 2007 | 06:30 AM
Default Re: (Jared)
what does this have to do with tech anyway, it should not even come close to being a failed item...and tech doesnt really look up way under your dash?
Old Jun 25, 2007 | 06:42 AM
DaveF's Avatar
a saftey factor so you cant start the car unless you are sitting in it?
i know our racecars are "start-a-ble" with out pushing the clutch pedal in. although it would be smart to utilize this saftey feature.
Old Jun 25, 2007 | 06:47 AM
oh, i dont think twice on that, ive always undid that feature on my race cars.
