same mounts?
Old Jun 23, 2007 | 04:18 PM
civicstyles~'s Avatar
Default same mounts?
im just throwing a 89 dx tranny onto my 89 sohc zc to hold me over until i can find an SI tranny but i was just wondering if the DX and the ZC tranny use the same mounts? it looks like the front and rear mounts with match up fine but the mount on the passenger side looks like it wont even be close, i would just like to know before i get everything bolted up and the mount doesnt fit.
thx in advance.....
Old Jun 23, 2007 | 04:35 PM
yz125rider21's Avatar
it will work...
Old Jun 23, 2007 | 05:56 PM
hmmm thats interesting because i just go the tranny bolted to the engine and it doesnt even come close, the mount for the zc had a stud that went through the tranny with a nut on the bottom side but on the dx tranny there is no where for this stud to go :S the other two are good so im stumped as to why this one would be different?
Modified by civicstyles~ at 8:38 AM 6/24/2007
Old Jun 24, 2007 | 05:36 PM
removed the stud....or take pictures and point out what your talking about...the studs do come out if thats what needs to be done and put a bolt in there instead.
Old Jun 24, 2007 | 06:05 PM
its not just that though, there are three threaded holes on the trans that should fit up to the mount on the far passenger side and there is only two on the mount (including the stud if taken out). the two holes that are on the mount are both about 1.5 -2'' away from lining up with the threaded holes on the tranny... there no way i could possibly see this working so i will just go ahead and order a new dx mount, hopefully it will be different than this mount.
p.s. i will post pics tomorrow afternoon
Old Jun 24, 2007 | 06:43 PM
Crx Jimmy's Avatar
Default Re: (civicstyles~)
maybe you dont have a zc tranny maybe its a old integra dual cam tranny
Old Jun 24, 2007 | 10:26 PM
ZCMeGone's Avatar
Default Re: (Crx Jimmy)
are the mounts the same, but just a little bit longer? Cause i had that problem with my ZC and i drilled holes on the mount and its as smooth as, whatever metaphor you can think of
quik1
Nov 18, 2005 04:51 PM
93integra-racer
Nov 16, 2004 03:23 AM
Drake
Nov 4, 2003 04:24 PM
civbeater90
Sep 28, 2002 04:51 AM
