Would this work for adjusting the clutch?
To adjust the clutch's engagement point u loosen the nut on the push rod located on the master cylinder by ur clutch pedal, just use a 12mm wrench, loosen the nut a bit, then play with the rod and give urself some more length in the rod then tighten the nut back up and u should have a higher engagement point, or do the opposite if u want to lower ur engagement point.
krysted9354
Dec 30, 2008 09:19 PM
