Front license plate screw rusted in bumper!
Old Jun 23, 2007 | 01:37 PM
shortlid's Avatar
Default Front license plate screw rusted in bumper!
Ok, with the Northern New England winters and salt they put on the roads for 9 months of the year the '99 Civic 103k is worse of teh wear. I have had to sand blast some front sub frame members and re paint with frame paint. Paint was flaking off them with rust underneath. I thought a car built in Canada would have better underbody paint. Anyway I had to take the front plate off so I started unscrewing three of the STAINLESS machine I used to hold the front plate on. Well the top right one would not budge. Eventuly with to many tries with a big screw driver the head started to strip. So I went to vise grips. Well it started to turn then I heard a crack and the force had broken the METAL two nut backing in the front bumper for the top plate mounting bolts!! I can't get back there, what are my options.
Old Jun 23, 2007 | 03:56 PM
sitinthehall's Avatar
Default Re: Front license plate screw rusted in bumper! (shortlid)
A drill.
Old Jun 23, 2007 | 08:43 PM
Crx Jimmy's Avatar
just move the plate 1/4" to one side and use those self tapping screws right though the plastic. You will not notice 1/4" off center. And if you are super **** and want it dead center just oval the hole in the plate to the side 1/4" so the plate is centered.
Old Jun 24, 2007 | 05:36 AM
shortlid's Avatar
Default Re: Front license plate screw rusted in bumper! (Crx Jimmy)
I am cool with that BUT I can't get the old screw out casue now the backing nut is spining around inside the bumper!
Old Jun 24, 2007 | 08:25 AM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid &raquo;</TD></TR><TR><TD CLASS="quote">I am cool with that BUT I can't get the old screw out casue now the backing nut is spining around inside the bumper!</TD></TR></TABLE>
just grind the head off with a grinder or dremel
Old Jun 24, 2007 | 08:50 AM
shortlid's Avatar
GOOD CALL, I have a AC converter and a dremal will go do it right now!
matmcg
Paint and Body
Dec 6, 2007 06:39 AM
datssoled
May 14, 2006 12:39 PM
blackie
Feb 14, 2006 08:24 PM
syoh
Feb 7, 2005 12:57 PM
Don Jefe
Mar 13, 2004 12:27 PM
