(((i need to raise my car. How?)))
Old Jun 23, 2007 | 01:31 PM
USDMSiR's Avatar
Default (((i need to raise my car. How?)))
Ok, so im currently running tokico hp (non adjustable) struts and Eibach sportline springs and my car is slammed. like if i didnt have -3 deg of camber the tires would rub the fenders. Now my problem. I am installing an upper control arm type camber kit and when i lower the car down the control arm hits the frame. I hacked it out and tried my best to get it to clear but it just wont. I need to find a way that i can raise my car without buying new struts or adjustable coilovers. Im poor. is there any trick or way i can raise it? or buy a cheap adjustable collar? thanks
Old Jun 23, 2007 | 01:41 PM
WIZDOM's Avatar
Default Re: (((i need to raise my car. How?))) (USDMSiR)
did u make sure you have the stop washer on right on the strut rod??? if not that will make it slam to the ground even with just springs. raise it up open the hood and lower it back down and watch the strut rod as u lower it and if it moves up your stop washer is in the wrong place lemme know
Old Jun 23, 2007 | 01:53 PM
USDMSiR's Avatar
Default Re: (((i need to raise my car. How?))) (WZA 1)
its been more than 6 months since i've installed them. does that matter? would it still be drivable if like you said, the stop washer moves? lmk
Old Jun 23, 2007 | 01:54 PM
USDMSiR's Avatar
what i mean is ive been driving it. the stop washer goes on the strut and its on the very top of the fender well where the strut goes up?
Old Jun 23, 2007 | 02:50 PM
beatthisspeed69's Avatar
you can go to auto zone and they sell these things that you put in between the springs and you can raise them up...for like 5 bucks or something
Old Jun 23, 2007 | 05:57 PM
Hamstr323's Avatar
Default Re: (beatthisspeed69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 &raquo;</TD></TR><TR><TD CLASS="quote">you can go to auto zone and they sell these things that you put in between the springs and you can raise them up...for like 5 bucks or something</TD></TR></TABLE>
but those pop out I had them on my car for like 6 months and 1 by 1 they were left somewhere
Old Jun 23, 2007 | 06:21 PM
EFHATCHMAN's Avatar
Default Re: (Hamstr323)
No VatoZone specials!
BAD IDEA!!
Old Jun 23, 2007 | 07:58 PM
yea i know there not good but he said he was poor and needed a quick fix so that just popped in my head
Old Jun 23, 2007 | 08:09 PM
Crx Jimmy's Avatar
If you got those ebay arms, just grind more off, they are hit and miss. Mine fit almost fine one side barely scraped and when the paint wore off it cleared fine the other side hit by like 1/4" . I just drove around hard for like 5 minuted it clearanced itself
Old Jun 25, 2007 | 10:58 PM
WIZDOM's Avatar
if u pick up a repair manual it will show u the exact order all the parts go on the strut. lmk
Old Jun 26, 2007 | 07:30 AM
cr-x-91's Avatar
maybe u have the rear springs in the front and the fronts in the rear. my buddy has the same setup and his car does not get that low. What size rim n tie u running?
Old Jun 27, 2007 | 08:51 PM
USDMSiR's Avatar
Default Re: (cr-x-91)
i think thats what happened. i had to chop the rears because i bought the springs used and thought the guy who owned them before me cut the fronts. stupid me. lol. but anyways. right now i have the stock wheels on and the tire tucks up inside the fender. with teh gt3's (205/50/15) it would rub the fender if i wasnt at -3.5 deg of camber
matsgsr
Suspension & Brakes
Aug 24, 2012 11:37 AM
bopbop93030
Suspension & Brakes
Apr 4, 2009 05:33 AM
91tealhatch
Suspension & Brakes
13
Feb 14, 2007 08:23 PM
goldegg
Suspension & Brakes
Nov 14, 2006 12:19 PM
