can somone prove me that miror polished intake ports are bad?
Old Jun 23, 2007 | 01:23 PM
RACEPAK's Avatar
Default can somone prove me that miror polished intake ports are bad?
everybudy says it needs to be a bit rigid, i wanna know y.
Modified by RACEPAK at 3:10 PM 6/23/2007
Old Jun 23, 2007 | 01:41 PM
DonF's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (RACEPAK)
Look up boundary layer flow in you Aeronautics books. Or even look at a golf ball.
Old Jun 23, 2007 | 03:07 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: can somone prove me that miror polished intake ports are bad? (DonF)
You mean fluid dynamics.
And yes a certain amount of turbulance or Reynolds numebr higher than 3500 is required.
Old Jun 23, 2007 | 03:18 PM
DonF's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (mar778c)
Not really, a Reynolds number is not based on fluid flow. Or fluid dynamics. When is the last time you saw a "wet" wind tunnel?
Old Jun 23, 2007 | 04:21 PM
AznBlueBoy's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (Shhh I'm duckin GK)
my portflow head is polished.
what's wrong with that?
Old Jun 23, 2007 | 04:36 PM
Combustion Contraption's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (AznBlueBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">my portflow head is polished.
what's wrong with that?</TD></TR></TABLE>
wow.
Old Jun 23, 2007 | 04:47 PM
one slow coupe's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
wow.</TD></TR></TABLE>
lol. would like to know as well
Old Jun 23, 2007 | 06:23 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Not really, a Reynolds number is not based on fluid flow. Or fluid dynamics. When is the last time you saw a "wet" wind tunnel?</TD></TR></TABLE>
Ahh, no Don. Reynolds number can and is applied every where as a measure to determine the onset of turblence. It does not matter if it is a fluid or gas, "wet" or dry.
See here:
http://en.wikipedia.org/wiki/Reynolds_number
Old Jun 23, 2007 | 07:11 PM
Professor15's Avatar
from my understanding is that one reason for leaving the intake port a bit rough is to help mix the air-fuel ratio to create a more even burn.
Old Jun 23, 2007 | 09:10 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Ahh, no Don. Reynolds number can and is applied every where as a measure to determine the onset of turblence. It does not matter if it is a fluid or gas, "wet" or dry.
See here:
http://en.wikipedia.org/wiki/Reynolds_number</TD></TR></TABLE>
correct, but in a motor you wont get a reynolds that is anywhere close to 3500.
itll be orders of magnitude higher
Old Jun 23, 2007 | 09:43 PM
RMF Headers's Avatar
B A N N E D
Default Re: (Professor15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor15 &raquo;</TD></TR><TR><TD CLASS="quote">from my understanding is that one reason for leaving the intake port a bit rough is to help mix the air-fuel ratio to create a more even burn.</TD></TR></TABLE>
What do you think the air/fuel ratio is on a golf ball?
Old Jun 23, 2007 | 09:49 PM
d15Beta's Avatar
maybe it needs the rougher texture not by mixing the air fuel ratio but
to MAINTAIN the good mix... without turning the fuel into puddles on the wall or floor?
Old Jun 23, 2007 | 09:59 PM
doesnt fuel spray directly on the back of the valve in our B and K motors?
Old Jun 23, 2007 | 10:10 PM
RACEPAK's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">doesnt fuel spray directly on the back of the valve in our B and K motors?</TD></TR></TABLE>
thats what i was thinking...... it sparys on the valve.... so whats the deal?
maby some pepoles have been fooled over the years by efi and carb? and the card should have a rough surface?
Old Jun 23, 2007 | 10:32 PM
Black R's Avatar
25 Year Member
exhaust side, yep.
intake side, orly?
Old Jun 24, 2007 | 03:42 AM
7rrivera7's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
exhaust side, yep.
intake side, orly?</TD></TR></TABLE>
What does "orly" mean...Oh Really?
Old Jun 24, 2007 | 04:55 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: can somone prove me that miror polished intake ports are bad? (7rrivera7)
well...
it's talk about a lot, but i'm sure the difference is really under 1% of the flow, if that. As far as fuel atomizing, doubt on a honda port, and a tuned setup it would make a difference at all..
i've yet to see a solid test on the subject, questions like this remain up in the air, unless someone starts handing people dollar bills
Old Jun 24, 2007 | 07:57 AM
lude98SH's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (GarageAlchemist)
doesnt endyn do fuel atomization bumps or something to help atomize fuel ?? Ive heard of it but never saw anything on it.
Old Jun 24, 2007 | 10:01 AM
lohatch's Avatar
Default Re: can somone prove me that miror polished intake ports are bad? (lude98SH)
let me see your grill
Old Jun 24, 2007 | 11:41 AM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">
What does "orly" mean...Oh Really?</TD></TR></TABLE>
i'm thinking orally....orally polished is always best
Old Jun 24, 2007 | 11:50 AM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">doesnt endyn do fuel atomization bumps or something to help atomize fuel ?? Ive heard of it but never saw anything on it. </TD></TR></TABLE>
yupp
fcukt_teg
Nov 30, 2007 04:03 PM
mmmsushi
Oct 23, 2005 09:37 AM
Cyphear
Jun 20, 2004 03:51 PM
skribblah
Sep 9, 2003 08:05 PM
SHystrdyGSRtdy
Aug 21, 2003 06:06 AM
