PA install in 96 ex
I'm helping put a PA in my friends civic. There are 4 wires connected to the unit, 2 blue's for the speaker and then a red/black (+/- 12v) power wires. What is the best way to power this? Should I ground to the engine bay?
Thanks
Thanks
Turns out it's a 2000 ex, doesnt matter the 12v fuse inputs are still there. So if I went to pepboys/kragen etc. I could buy a 12v fuse that I can connect the power wires too?
Thanks for the quick reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMoonRulz »</TD></TR><TR><TD CLASS="quote">Turns out it's a 2000 ex, doesnt matter the 12v fuse inputs are still there. So if I went to pepboys/kragen etc. I could buy a 12v fuse that I can connect the power wires too?
You don't need a fuse, just a spade connector. Those accessory plugs are already fuse protected.
</TD></TR></TABLE>You don't need a fuse, just a spade connector. Those accessory plugs are already fuse protected.
Recks133
May 28, 2010 12:00 PM
