rhino arms, toe on one side way off, what do I do, I need help badly with this
Old Jun 23, 2007 | 12:29 PM
nexgen91's Avatar
Default rhino arms, toe on one side way off, what do I do, I need help badly with this
I finally got around to putting on my rhino adjustable UCAs today. well once I finished and got the car back on its feet, the toe on one side is way out, the front of the tire it sticking out of fender well, if I turn the wheel it shifts to the other side. what could be wrong. I also replaced my radius rods and bushings, is there a chance they could be upside down and cause this? thanks
Old Jun 23, 2007 | 12:40 PM
jlicrx's Avatar
Default Re: rhino arms, toe on one side way off, what do I do, I need help badly with this (nexgen91)
when you move the UCA out, the distance from the rack to the knuckle gets longer, so you need to lengthen the tie rods out - equal amount on both sides - you need to get a front end alignment
Old Jun 23, 2007 | 12:52 PM
nexgen91's Avatar
Default Re: rhino arms, toe on one side way off, what do I do, I need help badly with this (jlicrx)
is this normal for when adj UCAs are installed? it was not like this before with the OEM ones. thanks
crxaddikt
12
Nov 22, 2014 01:52 AM
EGGHEAD12
Mar 20, 2012 11:27 AM
dc2LS
Oct 17, 2010 10:08 PM
Home Skillet
Oct 18, 2002 11:18 AM
