AC fuse keeping blowing after compressor replacement.....95 Del Sol b16
Old Jun 23, 2007 | 12:11 PM
sPaRk'iT's Avatar
Default AC fuse keeping blowing after compressor replacement.....95 Del Sol b16
My buddy recently change his AC compressor because his old one wasn't working. After installing a civic used AC compressor it worked for couple of weeks then after that the fuse just kept on dying whenever the AC is used, i know forsure that there's a short somewhere, i haven't really look at the car yet but i need some ideas to look for the problem, i search but couldn't really find anything.
Modified by sPaRk'iT at 9:45 PM 6/23/2007
Old Jun 28, 2007 | 01:33 AM
sPaRk'iT's Avatar
Default Re: AC fuse keeping blowing after compressor replacement.....95 Del Sol b16 (sPaRk'iT)
TTT
Old Jun 28, 2007 | 01:53 AM
97civicdx's Avatar
Your gonna have to hand trace the wires coming off the comp. Shorts are a pain in the *** to track down and time consuming. Did it work ok before the comp replacement? Is it fully charged also?
Old Jul 1, 2007 | 01:11 AM
sPaRk'iT's Avatar
Default Re: AC fuse keeping blowing after compressor replacement.....95 Del Sol b16 (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Your gonna have to hand trace the wires coming off the comp. Shorts are a pain in the *** to track down and time consuming. Did it work ok before the comp replacement? Is it fully charged also?</TD></TR></TABLE>
Yes it was working fine before the com replacement.
Old Jul 1, 2007 | 06:59 AM
MatterMatt's Avatar
On most AC compressors theres a little harness called a rectifier bridge that has a barrel connector and the connector that connects the compressor to the ac pressure switch. Those sometimes get corroded or beat up,and can cause high resistance faults that will blow fuses.
Old Jul 2, 2007 | 01:36 PM
sPaRk'iT's Avatar
Default Re: AC fuse keeping blowing after compressor replacement.....95 Del Sol b16 (MatterMatt)
Cool any more ideas guys?
pro1911
Jun 29, 2024 09:52 AM
Rhett511
Honda Civic (2001 - 2005)
Mar 15, 2015 11:05 AM
redsub9802
Nov 1, 2006 02:54 PM
dc2jdmteg05
Jul 20, 2005 12:37 PM
Sinner
May 1, 2005 07:19 PM
