*urgent* do i need feeding wire?
Old Jun 23, 2007 | 09:06 AM
codenamezero's Avatar
Default *urgent* do i need feeding wire?
For spot welding, so i need feeding wire?
i rent a welder last night, about to get things setup and weld my radiator support now...
i was reading spot welding stuff online and found this
http://www.esabna.com/EUWeb/MI...1.htm
do i <u>absolutely</u> need the "spot welding cup" for spot welding?
and again, do i need feeding wire? (i thought feeding wire is needed say to weld 2 separate piece or if it has groove.)
the welder i rent is Lincoln Weld-Pak 100HD, i read the description and i should set it to C-1.5 to weld ~1.6mm metal. (JDM rad support is like 0.5mm, the frame is about 1mm)
any input would be much appreciated!
Old Jun 23, 2007 | 11:05 AM
sharkytm's Avatar
If you had renteda spot welder, no.
You rented a MIG, so yes.
If you use Fluxcore wire, you'll need no gas tank or lines. If you use MIG wire, you'll need a tank, regulator (possibly), and Argon or Trimix, or in a pinch, CO2.
Old Jun 23, 2007 | 09:04 PM
dfoxengr's Avatar
Default Re: (sharkytm)
75/25 for mild mig.
kuja396
Welding / Fabrication
Mar 13, 2008 02:40 PM
LostAndFound
Oct 30, 2006 04:04 PM
C_H_A_D
42
Aug 31, 2006 04:21 PM
twilightprotege
May 22, 2006 04:52 PM
fastcivicboy
Feb 19, 2005 01:02 PM
