Oil Temp Sender Install
Use the stock sensor location, on the back of the block next to the oil filter.
http://www.theoldone.com/articles/oilpressure/
for oil temp...go with a bung in the pan...the stock area described above is for pressure NOT temp. I have a bung in my pan...works great ZERO problems. I also have an extra pan I could get on welded in for you...if you wanted
Ciao'
Ciao'
My plan is to use and aftermarket Oil Pressure guage also. So I will follow Larry's directions to tap the stock oil pressure sender and the aftermarket sender from the spot near the oil filter. My question is: Is it possible to also tap the temp sender from the same area?
You can use the pressure point for temp, BUT I would not do that. You won't get an accurate reading of your temps. I would use the bung in the pan. That is where mine is and it looks factory. The welder at my shop is a pro to say the least. Once I added my oil cooler I could a major differnece in temps and feel that monitoring the temp in the pan is the best place. The pan is where 90% of the oil is most of the time....so that is where I want to take my temp reading.
Just my 2 cents
Ciao'
Just my 2 cents
Ciao'
Greddy and Z10 make a drain plug that has an NPT fitting that works for oil temp....very well, IMO
ttaplin
Oct 6, 2005 03:36 PM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
