reving probs
Old Jun 22, 2007 | 10:52 PM
88_lsvtec_hatch's Avatar
Default reving probs
i just put my ls vtec back together and i start it up, it starts up fine and runs good but will not rev past 2500 rpm. the cel is on but i try to jump the plug to see my codes and it wont flash me any. so i dont know wats going on. some people told me it was out of time and others say its in limp mode??? ne ideas?
Old Jun 23, 2007 | 07:27 AM
Default Re: reving probs (88_lsvtec_hatch)
come on guys, need some help here
Old Jun 23, 2007 | 01:53 PM
bump
Old Jun 23, 2007 | 05:44 PM
si90rex's Avatar
this car sucks...... were still having problems.
Old Jun 24, 2007 | 10:44 AM
i put the car in time correctly again but it still hasnt change so i have no clue wats the problem so ne advice would help. thanks
Old Jun 24, 2007 | 03:46 PM
some ones got to have an idea on wats my problem??? ne one???
Old Jun 24, 2007 | 04:00 PM
4g hatch's Avatar
is it obd-0 or 1
Old Jun 24, 2007 | 05:55 PM
si90rex's Avatar
Default Re: (4g hatch)
its a obd1 p30
Old Jun 24, 2007 | 07:09 PM
Crx Jimmy's Avatar
Default Re: (si90rex)
sounds like limp mode, if it was chipped improperly or had a bad chip or damaged in some way the ecu will revert back to limp mode
Old Jun 24, 2007 | 09:21 PM
it wasnt chipd. but i did figure out the codes i got 6,7,10, and 14. i got a new tps and put it on but that didnt make a diff, and i always have a code for the iacv and its never made it do this, but could the coolnt temp sens. or the iat sens. make it do this??? those are the other two codes that it gives me
Old Jun 24, 2007 | 10:19 PM
civic_jdm16's Avatar
Default Re: (88_lsvtec_hatch)
code 10 air intake temp would do it..... 4 shure
Old Jun 25, 2007 | 07:10 AM
well ill try to see wats the problem with it or get a new one but if that dosnt take care of it this is gona suck
Old Jun 26, 2007 | 12:26 AM
so i figured it out. i finally got some time and i was diagnosing the problem and the neg. wire to the tps sensor was pulled out of the jumper harness so i hooked it back up and it runs good!!!! thanks guys!!! NOT cause know one likes to help except for civic_jdm16 thanks buddy for trying. na im jk guys but keep up the good work, later
Old Jun 26, 2007 | 07:07 AM
not a problem I know how bad things can get when you have pretty much tried everything with no results.... those late nights lying awake in bed being pi$$ed off lol
raguilar7
Dec 6, 2010 06:08 AM
91C1V1C
Sep 24, 2008 09:40 AM
2000siturboR
Jun 23, 2008 12:00 PM
RenzoDaPlayboi
Mar 8, 2006 03:29 PM
mstolars
Dec 25, 2005 09:29 AM
