For Those Who Have Removed Heat, Fitting Size??
Need to find the thread sizing of the hose-barb off the side of the head, to the lower left of the vtec solenoid that the heater-hose is clmaped too.
Removed the heating system, just need to find the appropriate plugs
I know the plugs that go in the rocker arm holes fits and looks good, Iam talking about the allen headed plugs on both sides of a B vtec head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRID_H@TCH »</TD></TR><TR><TD CLASS="quote">I know the plugs that go in the rocker arm holes fits and looks good, Iam talking about the allen headed plugs on both sides of a B vtec head.</TD></TR></TABLE>
yes sir ! this is what works !
Exactly, I just did this the other day also. Shad told me about that one
Thanks guys, when I initially did this last night it threaded a bit weird, but with everyone suggesting it, a little thread sealant and the fitting should do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">went to pep boys, to the help section, got some coolant bypass hose caps. </TD></TR></TABLE>
I wouldn't do that, rubber caps on water lines will fail. it's not a matter of if, it's a matter of when.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
I wouldn't do that, rubber caps on water lines will fail. it's not a matter of if, it's a matter of when.</TD></TR></TABLE>
it always seem to happen at the worst time too, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">
it always seem to happen at the worst time too, lol</TD></TR></TABLE>
usually around Elimination Rounds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano »</TD></TR><TR><TD CLASS="quote">Why cant you just loop the both nipple with a heater hose? I'm thinking about doing that to my car.
Adriano</TD></TR></TABLE>
you can, but why would you clutter the engine bay more with a loop hose, when a simple threaded allen head plug will do a much cleaner and reliable job? at somewhat simlar cost levels, or free if you have an extra plug layin around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
you can, but why would you clutter the engine bay more with a loop hose, when a simple threaded allen head plug will do a much cleaner and reliable job? at somewhat simlar cost levels, or free if you have an extra plug layin around.</TD></TR></TABLE>
its a jersey thing, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtor Boost »</TD></TR><TR><TD CLASS="quote">Just did it on mine to. But I used a rubber cap plug on the niple on th eback of the block.
what should be used on the back niple??</TD></TR></TABLE>
heat it up, pull it out, thread with NPT tap, thread in NPT plug. done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">its a jersey thing, lol</TD></TR></TABLE>
lmfao...the hex head plug for the rocker arms threads in a bit weird, a little teflon paste and i'll be good to go...thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">
they are the same pitch.. the allen head plug, also uses the crush washer on it, (you dont need teflon paste)
</TD></TR></TABLE>they are the same pitch.. the allen head plug, also uses the crush washer on it, (you dont need teflon paste)
Sorry to bring this back, what have you guys done with the barb off the back of the block right below the waterpipe?
Have it welded shut I'm assuming? Is it 3/4" BSPT?
where the oil cooler hose connects to the block ?
i just looked through my teg service manual, and had no luck finding what that pipe's size/pitch are...
but my suggestion would be to either
A. get an allen head style plug in 3/8 bspt(if you can find it) might want to try mcmaster.com or a place like that.
B. tap it to 3/8 npt, and put an allen head plug in place.
Modified by dturbocivic at 12:43 PM 7/4/2007
