Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Who here has changed the type of oil they use.
Old Jun 22, 2007 | 08:51 PM
2004es2's Avatar
Default Who here has changed the type of oil they use.
Wassup all,
Has any of you guys changed the vescosity of your oil to 5w30 or is it bad to do this. My autotech teacher says that the only reason honda uses 5w20 in our cars is to get better gas milage and it dosen't protect that well against wear and tear. What are your oppinions?
Old Jun 22, 2007 | 09:24 PM
03EM2guy's Avatar
Default Re: Who here has changed the type of oil they use. (2004es2)
it'll be fine. you wont be able to tell a difference
at one time i was runnin 0w20
Old Jun 22, 2007 | 10:31 PM
sloem2's Avatar
Default Re: Who here has changed the type of oil they use. (03EM2guy)
i ran 5w 3o for a awhile and didnt notice the diffrence
Old Jun 23, 2007 | 01:30 AM
TailZ's Avatar
Default Re: Who here has changed the type of oil they use. (sloem2)
yeah like the rest said it'll be fine.
it's pretty hard to look for 5w20 around here.
i'm using 5w30 Mobil1.
Old Jun 23, 2007 | 02:46 AM
2004es2's Avatar
Yeah i figured you wouldn't gain anything except better protection but i wasn't sure if it would affect the gas milage ormake it harder to make power due to a little bit more restriction because of the higher vescosity.
Old Jun 23, 2007 | 02:08 PM
Vantage's Avatar
why not run what honda intended the car to run on? I dont see any point in getting anything but whats meant for the car.
Old Jun 23, 2007 | 04:50 PM
bravo831's Avatar
Default Re: (Vantage)
ive herd after 75,000 miles to go 10w30
Old Jun 24, 2007 | 01:11 PM
Curiouz_G's Avatar
5w20 is what honda recommends. Depending where you live, you might need thicker or thinner motor oil.
Old Jun 25, 2007 | 05:08 AM
anonnonator's Avatar
Default Re: (Curiouz_G)
""The main point to remember is to change your car's oil every 3 or so months or 3,000 miles, (or what your manual says)! Using the correct oil weight for your car is absolutely essential. This is usually notated in the owners manual and on the fill cover. If your car calls for 5W-30, then be sure to use 5W-30 in the winter time or you may experience problems with your car. Old-school logic dictated use of 10W-40 all year long but this is now considered outdated having been proven otherwise via laboratory testing. If your car calls for 5W-30 you probably have tight valve clearances on your engine and use of a 10W-40 product could cause it not start when the temperatures are colder. This is due to the valves being held open too far and from the lifters being pushed too far by heavier, slower moving oil.""
-Honda makes percision engines with not a lot of clearance in the internal components. That's why they call for 5w20 (newer civics). I run 5w20 synthetic. It is more expensive, but hey, it is worth it in the short run and long run.
I ran 10w 30 before in the winter, but I get some cold *** weather here in Canada so
the viscosity i put in is higher for the colder weather.
Old Jun 25, 2007 | 12:05 PM
Psychochik's Avatar
Since I switched to 5w20 synthetic a few months ago I have noticed my car running a ton better than before with just normal oil. Plus it lasts longer so you dont have to do an oil change every 3,000 miles. Instead I do mine ever 5-6k and thats with the certified Honda mechanice blessing. He said that 3k is optimum if youre out there racing or doing a lot of in town driving, but if youre like me and the majority of your miles are on the highway and not a lot of stop and go its all good to go a bit beyond that 3k mark.
If I had to change the oil every 3k miles I'd be changing my oil like ever 6 weeks.
Old Jun 25, 2007 | 04:25 PM
DankasCivic's Avatar
Default Re: (Psychochik)
I heard that ^^
Old Jun 25, 2007 | 05:26 PM
WhiteOnRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2004es2 &raquo;</TD></TR><TR><TD CLASS="quote">the only reason honda uses 5w20 in our cars is to get better gas milage </TD></TR></TABLE>
Don't tell the domestics!
d-ramey
Acura TSX
22
May 26, 2015 02:27 PM
pg
Jan 9, 2008 06:44 AM
Fliplm0de
Jun 28, 2006 01:20 PM
mattL
Nov 13, 2002 11:25 PM
RedLudeSH
Jul 25, 2002 05:44 PM
