Wheel Combo
Old Jun 22, 2007 | 06:43 PM
uscoastguard13's Avatar
Default Wheel Combo
I have a 1996 Honda Civic Sedan EX that has 14 inch wheels on it. I was wondering if a 2007 steel wheel and tire combo 205 55 R16 would fit under the Honda. Thanks!
Old Jun 22, 2007 | 07:14 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel Combo (uscoastguard13)
I doubt it, but you could try it. The 205/55-16 tires are 6 percent larger in diameter than your stock 185/65-14 tires, and that's a huge difference, almost an inch and a half larger in diameter. They might rub on the fenders and/or wheel well liners. On the other hand, if you like the wheels and you're not paying anything extra for the tires, you could try it, and if it rubs too bad, you're not really out anything. Worst case, you can always use the wheels, and replace the oversized tires with the 205/45-16 size that will work best on your car.
Old Jun 23, 2007 | 01:34 PM
r.wright's Avatar
Default Re: Wheel Combo (nsxtasy)
NO..they will not fit unless you have a 5 lug conversion on your car.. your civic is 4x100
Old Jun 23, 2007 | 07:00 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel Combo (Opossum Jenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">NO..they will not fit unless you have a 5 lug conversion on your car.. your civic is 4x100</TD></TR></TABLE>
When did the Civic go to 5 lugs?
Good call...
Nunya Buidness
Honda Civic (2001 - 2005)
Nov 14, 2018 10:43 AM
ocho.
Oct 14, 2011 10:07 AM
Transport
Mar 8, 2004 04:47 PM
happyman12
Feb 6, 2004 12:55 PM
D16madwoman
25
Jun 27, 2003 04:53 PM
