how to set the timing on single cam zc
yesterday i was accelerating pretty hard right before i went into third my car started sputtering and shut off so i started the car back up but it was sputtering and my timing belt on one side had a little slack in it so only thing i could thick of is my timing belt slipped so what i wanted to know is how to set the timing
hey axionm1k i see you live in victorville. I am located in apple valley right across the river. I had this same issue with my single cam zc in my crx so if you want any help let me know and IM me.
hey whats up im in riverside now i went to try setting the timing and when i pulled one of my plugs out i noticed it was smashed it looked like something hit it so noweveryone i talked to said the motor is no good but i want to know for sure before i get a new one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axionm1k »</TD></TR><TR><TD CLASS="quote">hey whats up im in riverside now i went to try setting the timing and when i pulled one of my plugs out i noticed it was smashed it looked like something hit it so noweveryone i talked to said the motor is no good but i want to know for sure before i get a new one</TD></TR></TABLE>
OH ****......do a leakdown or a compression test. Simple, inexpensive, and it will
tell you wether or not your motor is any good
the bottom of the spark plug was smashed!?! can pistons even go that high.. I dont think you need to adjust your timing it sounds like you need a new spark plug.... are you sure that plug wasnt already like that?
Girlfriends car sputtered real bad for about 6 months, i thought it was the timing it turned out to be a bad plug wire. you would get the same result from a bad spark plug...
If your spark plug did get smashed by you then your valves probably did to, your valves may be shot and you block may still be good... theres alot of things that could of happened just let us know
Modified by philkehn at 7:38 AM 6/26/2007
Ex-Eg-Driver
Jan 21, 2008 06:56 PM
hatchinprogress
Feb 7, 2006 06:37 PM
