will i still be able to use my skunk2 lower tie bar after installing ITR rear sway?
Old Jun 22, 2007 | 05:24 PM
mr nut's Avatar
Default will i still be able to use my skunk2 lower tie bar after installing ITR rear sway?
will i still be able to use my skunk2 lower tie bar after installing ITR rear sway? i just purchased the beaks kit for my car and i was looking at where my lower tie bar is and it looks like i would have to take it off. does anyone have the beaks ITR rear sway bar kit on their car with a lower tie bar install? thanks in advance. a quick response will be greatly appreciated because i plan on installing it right now.
sorry camera phone
Old Jun 22, 2007 | 05:45 PM
94rs-turbo's Avatar
yeah im almost 100% sure you gotta loose the skunk2 bro
Old Jun 22, 2007 | 05:55 PM
SleeperGSR's Avatar
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">yeah im almost 100% sure you gotta loose the skunk2 bro</TD></TR></TABLE>
I think this also. I have a 96 gsr and i might have been able to have that and the stock sway bar and that. But i got an aftermarket sway bar that bolts into the same holes that the lower arm bar does so i couldn't have the lower arm bar. You may be better off keeping your lower arm bar and not adding the stock sway bar if it doesn't fit. Anyone else have any thoughts?
Old Jun 22, 2007 | 06:00 PM
DBiNfEcTeD*'s Avatar
Default Re: (SleeperGSR)
absolutely cant put on the tie bar................the beaks brackets are in the way!!....sell it!!
Old Jun 22, 2007 | 06:02 PM
mr nut's Avatar
Default Re: (DBiNfEcTeD*)
DAMMIT!! i like how it looks down there though hahaha.
Old Jun 22, 2007 | 06:05 PM
DHutch's Avatar
Default Re: will i still be able to use my skunk2 lower tie bar after installing ITR rear sway? (mr nut)
You'll be able to run the ITR bar with the skunk2 brace, however, the beaks brace is not gonna fit unless you lose the S2 ... basically, one subframe brace: either beaks or Skunk2
Old Jun 22, 2007 | 06:15 PM
SleeperGSR's Avatar
Default Re: will i still be able to use my skunk2 lower tie bar after installing ITR rear sway? (DHutch)
the skunk2 might be better than a stock bar? any thoughts?
Old Jun 22, 2007 | 06:17 PM
Default Re: (mr nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr nut &raquo;</TD></TR><TR><TD CLASS="quote">DAMMIT!! i like how it looks down there though hahaha. </TD></TR></TABLE>
trust me dawg, id rather have the sway bar than the tie bar any day of the week!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pretty sure most will agree.............
Old Jun 22, 2007 | 07:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
sell that and get your self a ASR brace.
Old Jun 22, 2007 | 10:57 PM
Liquidgsr's Avatar
Default Re: (00IntegrAllmotoR)
you can keep it if you get the beaks kit for the lower tie bar. I have the beaks kit for my lower tie bar to fit. It just a spacer that spaces it out a bit so it will fit just past the bolts for the beaks ITR sway bar kit. This is a seperate kit for the lower tie bar fit. Check there website.
Old Jun 23, 2007 | 08:50 AM
mr nut's Avatar
Default Re: (Liquidgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">you can keep it if you get the beaks kit for the lower tie bar. I have the beaks kit for my lower tie bar to fit. It just a spacer that spaces it out a bit so it will fit just past the bolts for the beaks ITR sway bar kit. This is a seperate kit for the lower tie bar fit. Check there website.</TD></TR></TABLE>
thanks man.
Old Jun 29, 2007 | 06:46 PM
94 ls teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">sell that and get your self a ASR brace.</TD></TR></TABLE>
im with him the asr brace is really nice and it also comes in black
Old Jun 29, 2007 | 08:03 PM
TastyDragon's Avatar
Default Re: (94 ls teg)
will all rear lower tie bars not work with tha beaks kit?
Old Jun 29, 2007 | 08:36 PM
Liquidgsr's Avatar
Default Re: (TastyDragon)
i posted this early you need a beaks kit if you using a becuase sway bar kit. Again a beaks kit for you lower tie is different than the one for the sway bar.
Old Jun 29, 2007 | 09:18 PM
so if you use tha beaks reinforcement kit only tha beaks lower tie bar will work?
Old Jun 30, 2007 | 09:40 AM
mr nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TastyDragon &raquo;</TD></TR><TR><TD CLASS="quote">so if you use tha beaks reinforcement kit only tha beaks lower tie bar will work?</TD></TR></TABLE>
no. if you use the beaks reinforcement kit then you need to purchase a beaks extender/adaptor to use the lower tie bar that you have.
http://www.beaksproducts.com/L...t.htm
Old Jul 1, 2007 | 05:19 PM
do all rear tie bar work with tha asr subframe brace?
91 crx savage
Suspension & Brakes
Sep 7, 2010 01:45 PM
EusebioSam19
Suspension & Brakes
10
Dec 25, 2009 04:25 PM
blackstar
Oct 25, 2004 09:26 AM
b18C1_liLkyLe
Aug 12, 2003 08:09 PM
chiefvtec
Apr 10, 2003 08:25 PM
