Can you swap factory tachs in CRX cluster
Old Jun 22, 2007 | 02:49 PM
rustbucketrex's Avatar
Default Can you swap factory tachs in CRX cluster
I have a stock DX cluster with a tach that acts up every now and then. I also have a ZC cluster that I picked up cheap but it didn't have the plugs. I don't really want to read KPH anyway. Can the ZC tach be removed from that cluster and put in the DX cluster.
Old Jun 22, 2007 | 03:28 PM
Jonknee's Avatar
Default Re: Can you swap factory tachs in CRX cluster (rustbucketrex)
why dont u try it since you have both clusters already
Old Jun 22, 2007 | 03:38 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rustbucketrex &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock DX cluster with a tach that acts up every now and then. I also have a ZC cluster that I picked up cheap but it didn't have the plugs. I don't really want to read KPH anyway. Can the ZC tach be removed from that cluster and put in the DX cluster.</TD></TR></TABLE>
I can pretty much garantee it won't fit. you would not believe how much different clusters are underneath the faces. I have even seen 2 matching gauges out of 2 matching cars and they were different internally???? the chances of fitting one from the ZC are slim to none. but hey yuo'll never know for sure till you see for yourself
Old Jun 22, 2007 | 04:46 PM
ludesrv's Avatar
88-89 Work with eachother. 90-91 for the rest. The covers have to be of that year aswell.
I know there are SOME wiring differences in the earlier ones, but I would plug it in and try!
Old Jun 23, 2007 | 07:46 PM
Default Re: Can you swap factory tachs in CRX cluster (VtecSyndrome)
I appreciate the posts, maybe one day soon I'll crack 'em open and see.
89sicivic
May 25, 2006 10:43 AM
JapJunkie
54
Oct 19, 2004 05:38 PM
t0eKnEe
Aug 28, 2004 10:09 PM
spettinger
Jun 18, 2002 04:04 PM
