Painting Valve Cover.. ???
Old Jun 22, 2007 | 02:04 PM
4twenty_CRX's Avatar
Default Painting Valve Cover.. ???
So I'm gonna paint my D16 valve cover... Do I Need Primer???
Old Jun 22, 2007 | 02:29 PM
89efDUSTY's Avatar
Default Re: Painting Valve Cover.. ??? (fin781)
no primer is needed, just use aircraft stripper followed by wet sand...then use wrinkle/krinkled paint normally called wrinkle paint. This method will have it come out the best, and make sure to follow the directions on the car...applying coats takes effect in different durations then other paints.
Old Jun 23, 2007 | 03:15 AM
fin781's Avatar
Default Re: Painting Valve Cover.. ??? (89efDUSTY)
IF it turns out bad, just use aircraft stripper, its like a spray, and it takes the paint right off, its good stuff.
Old Jul 13, 2007 | 10:19 AM
Default Re: Painting Valve Cover.. ??? (4twenty_CRX)
Alright so I got my valve cover off and I've decided to go the Dupli-Color way. There's an awesome Gold I found which I'm also gonna be painting my Intake with. I'm ready to strip the old paint BUT-- is there a trick to getting the bolts out of the valve cover or do they not come off? Do those little washers come off on the inside? Also, will normal primer be able to withstand the heat if I use Dupli-Color engine enamel on top?
Old Jul 13, 2007 | 10:33 AM
gator88's Avatar
no, high heat primer is required if primering. You dont always need primer though. The bolts also come out, just pull harder.you should replace the valve cover gasket and plug tube o-rings while its off if they arent minty fresh, just a few bucks.
Old Jul 13, 2007 | 10:46 AM
njn63's Avatar
Default Re: Painting Valve Cover.. ??? (gator88)
The valve cover does not get that hot, normal primer will work along with normal spray paint.
I was skeptical at first but mine has only scratched where the cable rubs and i painted it a year ago.
Old Jul 13, 2007 | 10:51 AM
just pull harder? lol, funny cause that's usually the first thing i try and it always ends up bad haha. Then how would i get the metal washers back on and to lock them in, or are they not even needed? And I'm getting mixed answers... Regular primer or "high heat" primer??
Old Jul 13, 2007 | 02:40 PM
Alright so I got the bolts out and stripped the old paint, I'm about to start wet sanding.... CAN I PRIME IT WITH REGULAR PRIMER WITHOUT ANY HEAT ISSUES??
Old Jul 13, 2007 | 04:29 PM
mengy007's Avatar
I want a clear valve cover now that'd be the s**t
Old Jul 13, 2007 | 09:42 PM
CEMAYHALL's Avatar
Default Re: Painting Valve Cover.. ??? (mengy007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote">I want a clear valve cover now that'd be the s**t</TD></TR></TABLE>
When the oil "splashes" and hits the inside of the vc, you'll now have a brown vc.
Old Jul 13, 2007 | 10:20 PM
EFM_ookie's Avatar
Default Re: Painting Valve Cover.. ??? (CEMAYHALL)
i used the aircraft remover and dupli-color hight heat primer and paint. It turned out great. Its better to put many thin coats of paint than fewer heavy coats
good luck and let us know how it turns out
Old Jul 13, 2007 | 11:09 PM
Default Re: Painting Valve Cover.. ??? (EFM_ookie)
that's a rule everyone should know, anyway, i'm loved the shaved top with no lettering... but I'm workin on a Z6 one, i gotta get the black out of the O in 'honda' haha. I used a "POLY" super stripper spray, turns green after to show you where you sprayed... took it off nice but made a big mess, had to scrape it off THEN wash. I'll get a pic of it tomorrow. But yea I have some leftover regular primer... what the f is the difference between "DUPLICOLOR" and "regular primer" lol?
Old Jul 14, 2007 | 12:58 AM
EFM_ookie's Avatar
i wrapped the valve cover in foil after i sprayed it with the aircraft remover. It helps it absorb the paint.
Old Jul 14, 2007 | 09:50 AM
turkishEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFM_ookie &raquo;</TD></TR><TR><TD CLASS="quote">i wrapped the valve cover in foil after i sprayed it with the aircraft remover. It helps it absorb the paint.</TD></TR></TABLE>
^helps alot. Keeps the stripper fron evaporating. It works longer/better.
Old Jul 14, 2007 | 10:18 AM
dem0nk1d's Avatar
EFM_ookie
what did you use to grind the letters out? grinder and grinding disc? it looks good. you didn't need to use any filler either?
Old Jul 14, 2007 | 11:08 AM
toastytheog's Avatar
Default Re: (dem0nk1d)
your paint job looks nice. i tried, and was impatient and made it look clumpy
Old Jul 14, 2007 | 01:45 PM
gator88's Avatar
a flap wheel on a grinder works the best i found, until the last very little bit, then like 40 grit on a palm sander. I have done 7 like this and not once used filler. 4 of which have been polished so if this tecnique didnt work, imperfections woulda shown. Sorry, dont have pics cause i dont own them.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">EFM_ookie
Old Jul 14, 2007 | 01:59 PM
Default Re: (gator88)
well my thumbs are now sore from sanding with 120-150 grit sandpaper, by hand this is what i've got so far... I'm gonna give it another shot of the stripper but there's just one problem... i left it out on the balcony and it fell off the edge onto the little platform on the second floor, so i gotta climb up and grab it.
Priming soon!
what do you guys think? I still gotta get in and around the spark plug holes which is a bitch...
Old Jul 14, 2007 | 05:51 PM
boosted timebomb's Avatar
Default Re: (4twenty_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4twenty_CRX &raquo;</TD></TR><TR><TD CLASS="quote">i left it out on the balcony and it fell off the edge onto the little platform on the second floor, so i gotta climb up and grab it.</TD></TR></TABLE>
LOL... so if it FELL DOWN why do you have to CLIMB UP to get it
Old Jul 14, 2007 | 06:40 PM
Default Re: (boosted timebomb)
There's a little stupid thing that overhangs from the 2nd floor, it got stuck up there, so I went down and had to climb up, either that or jump down from the 4th floor.... lol. Anyways, I primed it and it's looking real good so far...
Old Jul 14, 2007 | 06:52 PM
EFM_ookie's Avatar
I just used a dremel with some grinding wheel, then hand sanded with 80, then went to 120 grit. Finished it off with a scotch bright pad!
no filler needed...just tons of sanding by hand to get that smooth finish
Old Jul 15, 2007 | 11:45 AM
itsjusj0hn's Avatar
paint it yellow foo.
Old Jul 15, 2007 | 01:18 PM
Default Re: Painting Valve Cover.. ??? (itsjusj0hn)
GOLDDDDDDDDDDD baby, with matching intake :D
EDIT: primer pics...
i ran out of primer but this should be enough...
Old Jul 15, 2007 | 09:00 PM
EFM_ookie's Avatar
noooooice.. the gold i used is almost exactly the same color as my wheel!!!
Old Jul 16, 2007 | 11:11 AM
Kyoh's Avatar
What type of scotch bright pad did you use?
