Timing Adjust
Old Jun 22, 2007 | 11:13 AM
Blackcat_78's Avatar
Default Timing Adjust
Hey All
I installed a new distributor and after that the car seems the it takes sometime to start and when pushing the gas pedal all the way to the floor would take time to react. I'm about to check the timing on my Civic 00 ex (stock) and found some helpful instructions here how to do it but I have one question before I do it. do I have to align the Camshaft pulley too (see picture below) or do I only worry about aligning the Drive pulley.
Camshaft pulley
Drive pulley
Links:
Camshaft pulley
http://img503.imageshack.us/im...0.gif
Drive pulley
http://img511.imageshack.us/im...4.gif
TY All
Modified by Blackcat_78 at 1:12 PM 6/22/2007
Old Jun 22, 2007 | 11:29 AM
sageuvagony's Avatar
Default Re: Timing Adjust (Blackcat_78)
why should you have to adjust that timing? Do you mean you want to adjust your ignition timing? If so you have the wrong instructions
Old Jun 22, 2007 | 11:34 AM
Default Re: Timing Adjust (sageuvagony)
Yeah the ignition timing sorry I didnt put that. here is the deal, I installed a new distributor and after that the car seems the it takes sometime to start and when pushing the gas pedal all the way to the floor doesnt go anywhere so someone here told me to check the timing
I have the timing gun and tools but that was my only question
Old Jun 22, 2007 | 12:30 PM
Anybody?
Old Jun 26, 2007 | 11:01 PM
cosmoloks94eg's Avatar
just swapped a new d16z6
my timing is under 1000 rpm how do i advance the timing??
Old Jun 30, 2007 | 01:18 PM
crxhybrid.'s Avatar
cosmoloks juss advance the dizzy..
Old Jun 30, 2007 | 01:25 PM
Padawan's Avatar
Darth ModerVader
You are confusing cam timing and ignition timing. When setting the base ignition timing, you don't have to "align" any of the pulleys. Just jump the service connector, hook up your timing light, then start the car and point the light at the mark near the crank pulley. You can then adjust (rotate) the distributor until the timing mark lines up correctly.
90si-rex
Sep 20, 2009 08:47 PM
KRAZYBOUTSOLS
Jun 1, 2008 10:46 AM
MenaceL.A.671
Sep 13, 2005 04:10 PM
