GSR IAC on an LS Intake Manifold?
Old Jun 22, 2007 | 10:47 AM
BoltonGSR's Avatar
Default GSR IAC on an LS Intake Manifold?
Will a GSR IAC work with an LS intake manifold? Both OBD2
Old Jun 22, 2007 | 11:47 AM
BoltonGSR's Avatar
Default Re: GSR IAC on an LS Intake Manifold? (BoltonGSR)
Are they interchangeable?
Old Jun 22, 2007 | 11:55 AM
JDMorgan's Avatar
pretty sure all gsr's use the 90-93 integra style iacv, then all other 94-01 tegs use the newer style. you can use the wrong one with one bolt hole if it is an emergency. the bolt holes on a gsr iacv should be spaced out a little more than a normal 94-01 teg. blox manifolds have bolt holes for both.
Old Jun 22, 2007 | 12:07 PM
BoltonGSR's Avatar
Default Re: (JDMorgan)
Its a 96 GSR iac going onto a 97 LS manifold..
Old Jun 22, 2007 | 12:57 PM
BoltonGSR's Avatar
Default Re: (BoltonGSR)
Bump, can i re use my GSR IACV?
TRYLSTEG808
Jul 18, 2007 09:22 PM
integraballs
Apr 24, 2006 10:38 AM
crxowner
Feb 22, 2006 12:12 PM
STPREZ
Jan 27, 2005 02:55 PM
Josho_17
Mar 10, 2003 08:17 AM
