alternator bad?
Old Jun 22, 2007 | 08:53 AM
99JdmDc2's Avatar
Default alternator bad?
I got a 1999 integra gsr and my dash lights and driving lights seem a little dim, but when i rev up to about 4000 rpms the lights get bright like they should and and then once i get to lower rpms they dim back down, my connetors arent the best,but i have been driving around like this for awhile so i figured if it was the alternator the battery would be dead by now. any help. thanks
Old Jun 22, 2007 | 09:09 AM
super jdm yo's Avatar
Default Re: alternator bad? (99JdmDc2)
it could be your battery bro. did your battery die when driving, or when you left your car off. because all your alternator does is it re-charges your battery while the car is running.
your lights are probably because of your connections. get new nice and clean ones. maybe get a better ground like 4 gauge.
my suggestion to your would be to charge your battery up separately. and see if it'll hold a charge. and/or get another battery you know is good and drive around in that. if your car ends up dyeing out. it's your alternator. someone correct me if i'm wrong.
other than that goodluck on your car.
Old Jun 22, 2007 | 09:11 AM
ef_hatchback's Avatar
battery
Old Jun 22, 2007 | 09:49 AM
99JdmDc2's Avatar
alright i switch that out and see if that works. thanks
Old Jun 28, 2007 | 08:42 AM
99JdmDc2's Avatar
I had my battery checked and it was good, so then i switched alternators and then came to figured it out, it was the negative ground on the frame.
Old Jun 28, 2007 | 11:28 PM
nb0's Avatar
nb0
Take a voltmeter to your battery, it should be 12.5 or higher. Then at idle take a voltmeter to your battery, it should be 14.1 - 14.5 If it is over 15 then your voltage regulator is gone on your altenator.
slow_low_eddie
May 16, 2014 08:15 AM
Dcmonstr_33
Jun 28, 2013 11:47 AM
JasonYo
Sep 1, 2010 10:42 PM
mouch33
May 1, 2008 05:38 AM
whitehf
May 10, 2007 08:40 PM
