Why the hell wont the bolt go through the rear motor mount?
Old Jun 21, 2007 | 11:50 PM
swallow's Avatar
Default Why the hell wont the bolt go through the rear motor mount?
I'm swapping in a 96-98 jdm b16 into my 98 civic and for some odd reason the bolt on the rear motor mount doesn't want to start threading in and the engine looks a little crooked but there is no way to make it straight, can someone please help me!!!
Old Jun 22, 2007 | 12:33 AM
swallow's Avatar
Default Re: Why the hell wont the bolt go through the rear motor mount? (eksirIIyour_mom)
Bump....
Old Jun 28, 2007 | 11:45 PM
pine_apple45's Avatar
yea im having the same trouble too..i know that theres a lil play with the motor if that rear t bracket isnt connected..u can tilt it forward n back too..dunno if that helps or not.
Old Jun 29, 2007 | 12:16 AM
smileycvc's Avatar
Default Re: Why the hell wont the bolt go through the rear motor mount? (pine_apple45)
use a motor lift and just attach the chain to the back of the motor and lift slightly tilting the motor forward. Most likely the motor is just not lining up properly. Good luck.
Old Jun 29, 2007 | 04:02 AM
hatchnideas's Avatar
are the other mounts attached yet? if yes loosen them up as much as you can without removing and then try to get the bolt in again. i had a similar problem, even jacked up the engine and still nada. loosened mounts and then rebolted them all evenly and then it worked.
Old Jun 29, 2007 | 04:42 AM
sql_civic's Avatar
Default Re: (hatchnideas)
All good advice.
Old Jun 29, 2007 | 01:51 PM
Malakai's Avatar
u sure u have the right rear mount?
Old Jun 29, 2007 | 01:57 PM
EL Vap133's Avatar
Default Re: (Malakai)
Long breaker bar sometimes does the trick, move the engine in place.
DeDonDeRosa
Mar 14, 2010 09:56 PM
pinecone
11
Mar 25, 2006 02:04 PM
whitehf
Mar 3, 2006 02:44 PM
AzntaggeR
Feb 14, 2004 07:31 PM
Kato7997
Mar 4, 2003 06:03 PM
