Bad Radiator Fan Rattle - Should I replace motor or whole fan?
I had my car checked out about a month ago, I brought it in cause it sounded like the passenger side radiator fan was loose.. but they said it just needs a new fan cause the bushings are bad.
Well I have put it off, and now the rattle is really bad, but my question is, would the bushings alone cause a rattle? It almost sounds like the fan may be touching somewhere? Should I just replace the whole fan and motor, or just the motor?
And is the fan on the passenger side any different from the one on the drivers side? As in the motor? Do I need a special motor, or can I just get a Radiator fan motor from eBay?
Will this work? http://cgi.ebay.com/ebaymotors...71090
i got that and it worked fine, 2 yrs so far...i think, not very sure, the passenger side are little different...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtran002 »</TD></TR><TR><TD CLASS="quote">i got that and it worked fine, 2 yrs so far...i think, not very sure, the passenger side are little different...</TD></TR></TABLE>
Was it easy to replace?
Is there really any difference between the driver and passenger side fan? I think the one I linked too will work for the passenger side, it looks right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ndless »</TD></TR><TR><TD CLASS="quote">Is there really any difference between the driver and passenger side fan? I think the one I linked too will work for the passenger side, it looks right. </TD></TR></TABLE>
yes they are different; Raise the hood and have a look
I know they are different, but when purchasing a new fan and stuff, does it matter? One shroud is different than the other..
look at hondaautomotiveparts.com....there are part numbers and diagrams. call if you have to ...ask for River. I just bought $400 parts. They are pretty helpful...good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielb1 »</TD></TR><TR><TD CLASS="quote">look at hondaautomotiveparts.com....there are part numbers and diagrams. call if you have to ...ask for River. I just bought $400 parts. They are pretty helpful...good luck</TD></TR></TABLE>
Its 250 on there, its only 40 on eBay...
TheMacGuy
Oct 12, 2005 05:24 PM
