FS: CLEAN TITLE 92 SI or just motor
Old Jun 21, 2007 | 09:30 PM
jdmchris626's Avatar
Default FS: CLEAN TITLE 92 SI or just motor
selling for a friend::
CLEAN TITLE
B20 ITR BUILT asking $3,000 for the motor or $5,500 for the complete car
Here are the specs on the motor.
JDM B20B Stock bottom end
Custom crank case breathers were added to help with the excess crank pressure that builds inside these blocks.)
Unorthodox Crank & alternator pulley (revs up super fast)
B16 Head
ITR Dual Valve springs
ITR Retainers
ITR cams
New ITR intake manifold port matched to throttle body
BDL 68 MM throttle body tapered
Aftermarket performance fuel rail and fuel pressure regulator
Fidanza aluminum flywheel
Stage 2 clutch
Always ran on Motul oil
NEW ITR header with New Heat shield and skid plate
2000 Civic Si B16 Trans (no grinds)
Motul Gear oil
GSR axles
ITR shift linkages
Short Shifter
Motor mounts
Starter
Alternator
Distributor
P28 Ecu dyno tuned to motor by Whitfield Racing in Upland
Tunned on Chrome
Check engine set as shift light
2 step launch control
call 909 743- 1436 ask for chris thanks
Old Jun 21, 2007 | 09:34 PM
Default Re: FS: CLEAN TITLE 92 SI or just motor (jdmchris626)
bump
Old Jun 21, 2007 | 09:38 PM
night bump
Old Jun 21, 2007 | 10:27 PM
Jeanious's Avatar
bump
Old Jun 21, 2007 | 10:28 PM
bumpness
Old Jun 21, 2007 | 11:02 PM
Kovatch EG's Avatar
Whats built about it? you have a $500 bottom end and a $600 head?
Old Jun 22, 2007 | 09:22 AM
Jeanious's Avatar
Old Jun 22, 2007 | 09:25 AM
Jeanious's Avatar
Default Re: (Jeanious)
Dam bro... if you would read it clearly states that the motor is ITR built. Meaning all the internals on the head, plus intake manifold, plus header are are NEW ITR parts.
Old Jun 22, 2007 | 10:12 AM
Jeanious's Avatar
bump it
Old Jun 22, 2007 | 04:46 PM
haters keep the comments to your self--- BUMP
Old Jun 22, 2007 | 07:34 PM
Jeanious's Avatar
Bump....trades for Ek hatch are welcome..
Old Jun 22, 2007 | 07:52 PM
sL3epy187's Avatar
bump
Old Jun 23, 2007 | 09:23 AM
Jeanious's Avatar
bump it.
Old Jun 23, 2007 | 09:29 PM
Jeanious's Avatar
GONE!!!!!!!!
DMiller
Mid-Atlantic (Sales)
Jul 13, 2011 02:05 AM
4LugR
Northern California (Sales)
26
Jun 5, 2008 07:34 PM
NAstreetEH2
Sep 25, 2004 10:56 AM
Rhetoric
Oct 7, 2001 11:39 PM
