need a lil help and an answer...
i was driven to work today and noticed my tach wasnt workin for my mph but everything else is working fine. i tried searching but nothin came up. any ideas??
it sounds like your speedo isn't working. tach is fine right?
it's a cable that runs from the top of your transmission to the back of your gauge cluster. make sure it's properly attached in both of those places.
ooohhh i know the answer to this one!!
it the fuse!
check the red fuse on the bottom left hand side under your dash.
also check a couple of fuses in the black box under your hood.
this happened to me, and it was a burned fuse.
it the fuse!
mph = speedometer
rpm = tachometer
If it's the speedometer, it could be a multitude of things. Did you recently have the cluster out? If so, check to make sure the cable is all the way on.
rpm = tachometer
em2ssm02
10
Dec 10, 2006 01:44 PM
crxsi541
Jan 10, 2005 11:13 AM
