please help asap
Old Jun 21, 2007 | 06:50 PM
93baggedcivic's Avatar
Default please help asap
i have a d15b7.just rebuilt it got it back in the car and it wont start.just cranks.im not getting power to the injectors or and spark.all grounds are good and wires are tight what could it be?
Old Jun 21, 2007 | 06:58 PM
Default Re: please help asap (93baggedcivic)
BUMP
Old Jun 21, 2007 | 07:10 PM
anyone please
Old Jun 21, 2007 | 08:03 PM
slowcivic2k's Avatar
Start by confirming that the Crankshaft Position Sensor is wired/connected properly. This sensor sends a signal to the ICM which triggers your spark, and if it is absent, it will also cut fuel. Always start with spark problems, then fuel.
Each injector has a common hot wire for power (example grn/blk), controlled by a NPN driver in the ECU, ensure that there is 12V present at each injector power wire and body ground, if not, check your fuses and the injector wiring to the ECU. You will not be able to determine if the injector is firing with a multimeter alone. Check the coil primary for 12V with the key in the ON (II) position by probing the blk/yel wire on the distributor connector and body ground. Let me know what you find.
salemned
Sep 7, 2017 12:13 PM
Scout1856
Honda Civic (2001 - 2005)
Aug 6, 2016 01:01 PM
skaternak
Jul 18, 2009 06:55 AM
crispy93
Jun 10, 2009 02:36 PM
cslegacy
Feb 28, 2009 03:56 PM
