FS:96/00 Midori Green EK Hatch H-bomb
Its time to let the green machine go.
$11,000 OBO call 219-916-5996
Body:
Midori Green shell
Flat Black engine bay
2000 civic front end conv.
fog lights
type r lip
2000 Si gauge cluster
CF duck bill spoiler
no rust
minor dings
overall shell 8 out of 10.
Suspension:
D2 Full coilovers
Omni Power LCA's
GSR Front Brakes w/ new pads
Motor:
92 Jspec H22 Bottom end( car passes emissions)
bore 87.25mm
Polished Crank Shaft
Eagle Rods
Mahle 11.5 compression pistons/rings
Skunk 2 Valve Spring set
Skunk 2 Titanium Retainers
Skunk 2 High Comp Valve set
Skunk 2 Pro 1 cams
ARP head Studs
Skunk 2 Cam Gears
Hasport Motor Mounts
Fluidyne Radiator
Skunk 2 pro series Intake Manifold
Golden Eagle Fuel Rail
Precision 400cc Injectors
Blox Fuel Pressure Regulator
B&M Fuel Pressure Gauge
Waulbro 255 fuel pump
Baller *** RMF Race Header
Buddy Club Spec 3 exhaust
Transmission:
JDM trans
Quaife LSD Diff
M Factory 4.68 Final Drive Set
Gator Stage 2 axles
Exedy Stage 2 Clutch
ACT 9lb Flywheel
Misc stuff:
New Oil Pump
New Water Pump
Tension Conversion
New Timing Belt
New Distributor
New Alternator
NGK blue wires
Shoes:
15in Rota Gt3's Gunmetal
New Goodyear Hr2 Tires(4)
ECU:
Hondata s300
Check engine light shift light
2-stage launch control(7000rpm)
Dyno'd by Factory5motoring
232whp 165ft torque @8300rpm
everything is WHP
i probably forgot some stuff so ill add as i remember.
[IMG][/IMG]
[IMG][/IMG]
Modified by hseriesek at 2:33 AM 6/24/2007
Modified by hseriesek at 2:40 AM 6/24/2007
Modified by hseriesek at 1:47 AM 6/26/2007
Body:
Midori Green shell
fog lights
type r lip
no rust
minor dings
Suspension:
D2 Full coilovers
Omni Power LCA's
Motor:
bore 87.25mm
Eagle Rods
Skunk 2 Pro 1 cams
ARP head Studs
Skunk 2 Cam Gears
Fluidyne Radiator
Transmission:
JDM trans
Quaife LSD Diff
Gator Stage 2 axles
ACT 9lb Flywheel
Misc stuff:
New Oil Pump
New Water Pump
Tension Conversion
New Timing Belt
New Distributor
New Alternator
NGK blue wires
Shoes:
ECU:
Hondata s300
everything is WHP
[IMG][/IMG]
[IMG][/IMG]
SyLee Duk
Sep 4, 2015 12:01 PM
jdmrobby
Feb 15, 2013 07:25 AM
repost soon
