Strange Auto to Manual Question.
I currently have a 96 EX coupe and I am working on an auto to manual swap on it. With that said I have a question about throttle bodies and map sensors.
I am going to boost the car (I have most of the parts already) and I plan on going with a GM 3 bar but my question is: Can I use the GM sensor if it's not boosted on a stock ecu? If not, would a stock map from a 92-95 auto work? Does it boil down to a map sensor is a map sensor as long as it doesn't go over it's threshold on positive manifold pressure?
I also have an auto throttle body from a 94 DX that I am going to use so that I have the nipple on it already for a firewall mounted map sensor.
Thanks for the help on this one.
I knew that people use it for higher boost levels (hence the 3 bar part, the honda one is only good for a little over one bar? I think.) I was just unsure of if it sent out different signals. Thanks alot for the help. I'm actually using your swap guide.
B16Civic93
Apr 2, 2005 09:39 AM
