CTR BUILD ??????
Old Jun 21, 2007 | 04:55 PM
Horseofcourse's Avatar
Default CTR BUILD ??????
Is it possible to run A GSR BLOCK, B16A Head, CTR PISTONS, with LS Rods?
On zealautowerkz compression calculator it says with GSR rods it will have piston to deck height of .006 which is dam close but with b16 it will drop teh compression to low. But with the LS rods it seems like an almost perfect match.
Are all B-series rods the same Besides LS?
YES I SEARCHED
Old Jun 21, 2007 | 08:21 PM
slowcivic2k's Avatar
Default Re: CTR BUILD ?????? (Horseofcourse)
I believe the ctr piston has a larger pin diameter, which i think will require the ls rods to be machined to accept the ctr piston.
Horseofcourse
Jun 23, 2007 06:17 PM
detroitdiscounts2000
Oct 13, 2006 10:00 AM
egchan
May 24, 2004 09:23 AM
Ivan
Apr 24, 2003 03:42 AM
Ivan
Apr 23, 2003 09:49 PM
