Cleaning out my garage! Built B16, SOHC long/short blocks, lots and lots of misc. mounts/brackets/pa
LOCATED IN AND AROUND THE SO. CAL. LONG BEACH AREA. Everything is sold as-is. I will do my best to update this thread with new stuff as i find them. I dont have pictures for everything as that would take forever to do. I can be as descriptive as possible in regards to condition.
1997 ITR JDM parts with 17,xxx kilometers:
- Timing belt.
- Water pump.
- Both radiator fans.
- Power steering pump w/reservoir.
- Alternator.
- Halfshaft, aka intermediate shaft.
- Driver side axle.
- Complete oem oil cooler set up with water pipe, all fittings/hoses.
OBD-0/1 D series SOHC parts
- sohc vtec valve cover.
- sohc non vtec valve cover (2).
- set of 4 OBD-0 injectors.
- HF transmission.
- D16Z6 (usdm) complete intake manifold with all sensors/components. $75
- D16Z6/JDM D15B vtec solenoid (2).
EF/DA stuff that I found at the moment.
- USDM EF hatchback rear hatch with glass, shaved wiper and H badge holes, no wing, painted factory polar white. $40
- 2 Si PM6 ECU (year '90 and '89). $40 FIRM/each
- 1 Si PM6 MAP/purge assemblies (mounts to the firewall). $10
- 2 EF charcoal canister. $10 each
- 1 90-91 LS tranny complete but has Y1 5th gear, could have a trans issue, cant remember, you buy it for cheap and find out/fix it. $?
- 1 DX dpfi ecu. $?
- 1 90-91 DX (came from a civic hatchback) engine wire harness. Ready for mpfi conversion. $?
- D series crank pulley with keyway and bolt, 2 rib (no 3rd pulley for powersteering). $20
- D series crank pulley with keyway and bolt, 3 rib. $20
DOHC first gen B16 related parts: Some things arent pictured.
- Throttle body with TPS. $40
- Fuel rail. $10
Odds and ends:
- TPS sensors. $?
- EG sohc torque mount brackets (a/c and trans brackets). $?
- PR4 ecu, LS/RS/GS, 90-91, obd-0. $30
- B series halfshaft, came from a 97 del sol vtec b16. $40
- B series clutch slave cylinder with rubber flex hose. $15
- B series 92+ oem honda clutch disc. Used but 75% life left. $20
- B series VTEC rocker arms. 95% complete set, missing 1 middle rocker arm. $?
- B series rear main seal housing. $10
- B series flywheel (came off a '94 GSR), needs resurface. $30
- Exedy clutch disc for 92+ cable/hydro B series. Plenty of life left. $40
- B16A2 crankshaft. MINT/absolutely like new. $?
- JDM B20 throttle body w/ TPS and MAP sensor. $40
- IAT sensors and IACV's. $?
- B&M and stock fpr's. $?
- B series cable tranny throw out bearing fork and arm. $?
- Timing belt.
- Water pump.
- Alternator.
- Driver side axle.
- HF transmission.
- 1 DX dpfi ecu. $?
- Fuel rail. $10
Odds and ends:
- TPS sensors. $?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SqueezinEF »</TD></TR><TR><TD CLASS="quote">pm'd</TD></TR></TABLE>
Back at ya.
Back at ya.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeF »</TD></TR><TR><TD CLASS="quote">how much for the hatch cover?</TD></TR></TABLE>
pm'd.
pm'd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielk1 »</TD></TR><TR><TD CLASS="quote">willing to part an iacv? from your b16 intake mani? if it works, i'll take it :]</TD></TR></TABLE>
pm'd.
pm'd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXone »</TD></TR><TR><TD CLASS="quote">gewd shiet
More like too much shiet that i need to get rid of
Thx for the bump.
</TD></TR></TABLE>More like too much shiet that i need to get rid of
Thx for the bump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihkon »</TD></TR><TR><TD CLASS="quote">You know I'll grab that a6 block from ya. I just have to wait until next weekend.
Consider it yours.
</TD></TR></TABLE>Consider it yours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1797cc EG6 »</TD></TR><TR><TD CLASS="quote">BUMP FOR MY WHITE BROTHER...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">
good seller</TD></TR></TABLE>
