frustrated with swap
Old Jun 21, 2007 | 02:53 PM
CornerCarvin's Avatar
Default Less frustrated with swap
Before anyone tells me to search I have looked everywhere for answers(different sites too)I have been working on putting an 93 ls motor in my 90 Si for at least 2 months now and have yet to see anything that has given me hope of a successful swap. I started off trying to convert the motor from obd-1 to obd-0 with no avail(i had the obd0 parts lying around). So I decided to buy the rywire obd conversion harness I repinned the distributor and soldered the connections for the 4 wire o2 and the one wire knock. I had spark when I had the older dizzy on it and now after repinning the obd1 dizzy I have nothing. I have switched the 2 white wires around and still nothing. I am using the si harness on the motor too. the motor ran when I took it out of my teg but I cannot get it to fire in the si chassis. I am lost at the moment and would appreciate any help you can give me.
Modified by CornerCarvin at 9:52 PM 6/27/2007
Old Jun 21, 2007 | 04:31 PM
Default Re: frustrated with swap (CornerCarvin)
bump
Old Jun 21, 2007 | 05:33 PM
Crx Jimmy's Avatar
when using the si harness everything should be plugged in except 1 plug behind the manifold.
Old Jun 25, 2007 | 06:38 PM
I finally think I have the wiring taken care of. the only thing I am having a problem with is I am getting no spark, I have replaced the cap and rotor and everything was fine when I pulled it. I have checked my grounds as well(one of the first things I made sure was right when I put the motor in) and still nothing. any ideas?
Old Jun 27, 2007 | 04:42 PM
I found out that there was no bulb in the cluster for the check engine light so I put one in and I have a steady cell, does that mean my ecu is toast or could it be anything else? if it is toast what would be my options for replacing it?
jarhead90crx
12
Aug 5, 2011 07:06 AM
totoshatch
Jun 11, 2007 04:03 AM
CornerCarvin
May 12, 2007 03:03 PM
koleslaw
Mar 24, 2007 09:39 PM
lCHaCHeel
Sep 17, 2005 01:34 PM
