question on what ECU should i use. for b20
* B A N N E D *
ok i recently dropped a b20 ECU into my car
and I'm running it with a sohc non vtec ECU.
the bad thing about this ECU is that it sucks until it hits 4000 RPM and it feel very tuorquey after that.... until it cuts off at 6000 RPM so i only enjoy torque for 2000 RPMs
NOW when i use my Friend mugen chipped p28 ECU i dont feel that torque i feel with mine for those 2000 RPMs. why is it that his ECU is nice and juicy but not torquey like my sohc ecu.
sorry if the question is not so understandable but I'm not quite sure how ot describe this.
* B A N N E D *
yeah i got s b20 stock non vtec.
and i already have a p28...but it doesn't even run the car.
i guess i have to chip it.
what kind of chip do you guys recoment.
you can probably get a 94-95 LS ecu cheaper have that one chipped and sell the P28 or save for when you get a vtec head
no generic chip is going to be perfect for your motor unless its completely stock and you get a stock basemap
many be on here chip ecus
check out Pheareble.net HT user
there are many others on this board
p75 (LS ecu) has shown great improvemnts in non vtec SOHC.
Friends hatch with a Y7 (stock with bolton's) ran a 15.8 using a p75. Fuel map is a little more agressive than the stock 1.6 is.
Modified by 97Ej6mike at 12:28 PM 6/25/2007
* B A N N E D *
well i went ad bought a p75 and the car is still not a tuorquey as with the p06... but id does feel allot smoother. and it cuts at 7000
cool .
well if any body has asuggestion on a better ECU let me know. thanks guys.
cool .well if any body has asuggestion on a better ECU let me know. thanks guys.
P75 or PR4 is the only 2 i would consider if you dont want a custom tune.
either p75 or pr4 will get you the best out of the box tune.
only reason the p06 gives more torque down low is because it has a more aggresive timing curve.
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">
only reason the p06 gives more torque down low is because it has a more aggressive timing curve.
that's something I've iteresting been wanting to hear.
but does it ultimately beat the p75. or should i stick anything other the p06
cool
...but what does the pr4 come out of.
but does it ultimately beat the p75. or should i stick anything other the p06cool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow »</TD></TR><TR><TD CLASS="quote">that's something I've been wanting to hear.
cool
...but what does the pr4 come out of.</TD></TR></TABLE>
92-93 integra (obd1 as well)
cool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow »</TD></TR><TR><TD CLASS="quote">oh i have one out of one of those but it's OBD 0. and it a pr3??
is that what you ment.>??</TD></TR></TABLE>
no PR3 is a JDM zc ecu, and yes its OBD0, pr4 is USDM integra obd1 ecu, i think it was also used in 94s.
no PR3 is a JDM zc ecu, and yes its OBD0, pr4 is USDM integra obd1 ecu, i think it was also used in 94s.</TD></TR></TABLE>
Arent all integras 94-01 either p72 (GSR) or P75 (LS) ? i forget what the ITR's ecu is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Arent all integras 94-01 either p72 (GSR) or P75 (LS) ? i forget what the ITR's ecu is.</TD></TR></TABLE>
you might be right, thats why at first i said 92-93, i think you are right.
and i also think there is obd0 versions of the PR4
ITR = P73
ITR = P73
eg2oreg6watuwant
Apr 23, 2006 09:49 AM
