b20 trans. into integra???
hey wats up ... i was wondering if i swap a crv b20 transmission into an 94 ls integra...do i have to change the hydraulic clutch to cable or what?? Because the b20 has a cable clutch and the ls has a hydraulic clutch...and i have no idea what to do
B20's only came with automatic trannys. You can put the cable trans in your hydraulic set-up car with the hydro to cable conversion from hasport or the likes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 Dough »</TD></TR><TR><TD CLASS="quote">B20's only came with automatic trannys. You can put the cable trans in your hydraulic set-up car with the hydro to cable conversion from hasport or the likes.</TD></TR></TABLE>
thats not quite accurate. there are a few manual b20 trannies out there but its rare that youd actually come across one. most are AWD anyways so itd most likely be useless.
keep a hydraulic tranny at the least. what are your plans? n/a? turbo? if you just want something lightly modded than a b16 tranny will make that ls much quicker.
