Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
update! 37 fuse, -25+ lb
Old Jun 21, 2007 | 12:45 PM
Bulli Kid's Avatar
Default update! 37 fuse, -25+ lb
i had some free time so i decided to take out the spare tire and the kit. ended up taking a decent amount of weight of.
Chilling next to his buddies
Honda should have painted everything. GRR
then i pulled the Day time running light out.
basically go pop your hood and take out the fuze cover. under the cover there will be some spare fuses and a "fuze puller"
use the puller to pull fuze 37 out under the steering wheal.
just some random shots.
-Corners
- Main
- LOng
and my sleeper style club
Old Jun 21, 2007 | 12:48 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Default Re: update! 37 fuse, -25+ lb (Bulli Kid)
Is the 37 fuse soley for the DRL's?
Old Jun 21, 2007 | 12:49 PM
CerealKiller's Avatar
that's cool , but quick question, why do peeps want the drl off?
Old Jun 21, 2007 | 12:50 PM
Nighthawk R18's Avatar
Default Re: update! 37 fuse, -25+ lb (Tokyosmash!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyosmash! &raquo;</TD></TR><TR><TD CLASS="quote">Is the 37 fuse soley for the DRL's?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inlineaddict &raquo;</TD></TR><TR><TD CLASS="quote">that's cool , but quick question, why do peeps want the drl off?</TD></TR></TABLE>
personal reference. some people think it looks cleaner without it. or they try to be different
Old Jun 21, 2007 | 12:55 PM
Bulli Kid's Avatar
Default Re: update! 37 fuse, -25+ lb (Nighthawk R18)
i took out the DTR'l just because i dont like when my light are on at the day time all the time. plus i like when i roll up to my frinds or whatever and have just the corners on.
some poeple will say why do you take them off they are for saftly so people can see you better. Big deal when ever i feel i need my lights on i turn them on. ( bad weather, dark, morning.) duh
other wise i think they are useless.
Old Jun 21, 2007 | 12:56 PM
Shiftyshadee's Avatar
Oh, and don't forget that disabling saftey equipment is "trendy" and "unique".
Disabling DRL's FTMFL
Old Jun 21, 2007 | 12:57 PM
Bulli Kid's Avatar
this is a noob question but wont turning them off save you some electrical power?, helping other electronics work better
Old Jun 21, 2007 | 12:59 PM
It saves you absolutely nothing. Perhaps less "draw" on the electrical system, but how much power do the DRL's actually draw?
Not much IMO.
Sarge! Carry On!'s Avatar
Correct on the cleaner look and personal preference. When I enter a base or post, I know it plainly sucks when headlights are in your eyes, no matter how dim they are! Parking lights are the preference there.
I hate it too when I park somewhere and want to just have the parking lights on and those pesky DRL's are on too! Makes for bad pics, and dull appearance. If I want my lights on for safety, Ill turn them on! (Which I do now every time Im on the road!) Sorry for the long reply, on a roll I guess!
Old Jun 21, 2007 | 01:03 PM
TRE_'s Avatar
Default Re: update! 37 fuse, -25+ lb (Sarge! Carry On!)
So did you pull the spare & tool kit out just to weigh it or are you leaving it out of the car for "weight savings" ?
Old Jun 21, 2007 | 01:05 PM
Default Re: update! 37 fuse, -25+ lb (TRE_)
Or is your car a transformer?
So that if you get a flat tire it can transform into robot form and walk you home.
Old Jun 21, 2007 | 01:07 PM
might wanna keep the spare. it saved me once, you never know when you might need it.
besides 25 lbs in nothing unless your car is bare and used only for track.
Old Jun 21, 2007 | 01:14 PM
Bulli Kid's Avatar
i took it out. o ill see how my mpg average over 2 tanks. most liekly i will be putting it in.
Old Jun 21, 2007 | 01:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">
besides 25 lbs in nothing unless your car is bare and used only for track.</TD></TR></TABLE>
x2
Old Jun 21, 2007 | 01:47 PM
E-Money's Avatar
Default Re: update! 37 fuse, -25+ lb (inlineaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shiftyshadee &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and don't forget that disabling saftey equipment is "trendy" and "unique".
Disabling DRL's FTMFL </TD></TR></TABLE>
Old Jun 21, 2007 | 02:14 PM
MonkeyConQueso's Avatar
Only thing that sucks about the spare is that we can't use it for the fronts (Si only). Have to jack up the rear, take it off, put on spare, put rear on front, put flat in trunk...ugh. Of course just having LSD makes up for all of this, but...
I don't want to get a flat in front ever, anywhere.
Hellzcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sarge! Carry On! &raquo;</TD></TR><TR><TD CLASS="quote">Correct on the cleaner look and personal preference. When I enter a base or post, I know it plainly sucks when headlights are in your eyes, no matter how dim they are! Parking lights are the preference there.
I hate it too when I park somewhere and want to just have the parking lights on and those pesky DRL's are on too! Makes for bad pics, and dull appearance. If I want my lights on for safety, Ill turn them on! (Which I do now every time Im on the road!) Sorry for the long reply, on a roll I guess! </TD></TR></TABLE>
Correct me if I am wrong, please, but on my SI, the DRL's are only on when I am in gear with the engine running. Sitting parked somewhere with the engine running, the DRL's will go off unless your sitting in gear with your foot on the clutch. But like I said, this is how they work on my car. I discovered this when I installed my HID's.
Old Jun 21, 2007 | 02:22 PM
TRE_'s Avatar
Default Re: update! 37 fuse, -25+ lb (Hellzcivic)
The moment the ebrake goes down the DRLs will turn on until the vehicle is completley turned off.
Old Jun 21, 2007 | 02:32 PM
Yup, correct! At least on the Ex Coupe thats how it goes!
Just ordered fog lights and Fujuta CAI! My little Royal Blue Pearl baby is getting there, piece by piece!
Old Jun 21, 2007 | 02:35 PM
Hellzcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">The moment the ebrake goes down the DRLs will turn on until the vehicle is completley turned off.</TD></TR></TABLE>
Thanks for the correction Trevor. I know something else had to happen for the lights to go on. I thought it was when it went into gear. I never thought about the fact that I put the car in gear and then release the ebrake. I associated it with putting the car in gear, not the brake.
I thought they went off automatically when I sat in a parking lot waiting for my son a couple months ago. But now that I think about it, your right, I turned the ignition all the way off and then back on to reset the nav, that must have been when they went off. I just remember noticing them off when I looked up.
Again, thanks for the correction and my apologies for any erroneous info.
Thank you again sir.
Old Jun 21, 2007 | 02:47 PM
Say, how do you like your Eclips head unit? Im searching for a good Navi unit.
Old Jun 21, 2007 | 02:56 PM
originalg00kster's Avatar
Show me a post or anything that shows an accident was due to because the DRL'S weren't on. or show me a post where someone almost got in an accident but because the DRL'S were on...no accident was there. until than i beleive that the DRLS are for no use in safety, what so ever.
Old Jun 21, 2007 | 03:01 PM
Default Re: update! 37 fuse, -25+ lb (originalg00kster)
Well, being in law enforcement for several years, they do help during daylight driving, BUT, BUT............in my opinion they cause folks not to turn on their headlights on at dusk and near dark in town because they "think" their lights are already on! However, their taillights arent on!!!!!!!
I think they are probably better on motorcycles and not the cars really, they do help on really dark cars or really white cars I guess.
Enough on this area! LOL
Old Jun 21, 2007 | 03:20 PM
Hellzcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sarge! Carry On! &raquo;</TD></TR><TR><TD CLASS="quote">Say, how do you like your Eclips head unit? Im searching for a good Navi unit.</TD></TR></TABLE>
I love it, all except the annoying voice that speaks to you like you are an idiot when using "guidance" on th nav. I mean, how many time do I need to be told to turn right at the next intersection. I am sure the voice can be turned off, but I have not had time to read the novel (called the Owners Manual) that came with the unit.
Other than that, I could not be happier. The nav is super accurate and sound quality is awesome. Being able to entertain my son with DVD's when we are on a road trip makes up for the annoying voice.
With all the amplifiers and subwoofer, I get a ton of looks on the road when my son is cranking Star Wars on the DVD player.
Old Jun 21, 2007 | 03:27 PM
jdimi34's Avatar
I get a little discount from my insurance company for having DRL'S.
