somethin wrong with my hatch...dont know what it is.
Old Jun 5, 2002 | 10:10 PM
wu tang's Avatar
Default somethin wrong with my hatch...dont know what it is.
ok...my first problem is my hatch does this weird clicking noise. its only when i shift gears. sounds like its coming from my axles?? i could be wrong. but it drives normal.
secound problem is that my car smokes. im getting no codes and it smokes. my friend told me i could be burnin to much oil?? how do i fix this. cause im tired of driving a smoke stack. thanks for your help. peace
Old Jun 5, 2002 | 10:34 PM
shroomyman's Avatar
Default Re: somethin wrong with my hatch...dont know what it is. (wu tang)
shame on a ***** who try to run game on a *****. wu tang is the **** and as a fellow shaolin style ninja i solute you.
Old Jun 5, 2002 | 10:40 PM
shroomyman's Avatar
sorry i had to do that. What the clicking might be is you clutch might be ready to go becausemy friends car was doing that right before his clutch was just gone. I think he couldnt back up, and he could only move in second gear. The smoke is probably just burning to much oil and you need to fixit because it is seriously going to **** something up in the long run.
Old Jun 5, 2002 | 10:41 PM
90_Civic_Hatch's Avatar
The Clicking could be a couple of things. Does it do it when you push the clutch down or let it up? The smoke could also be a couple of things. 1. you may need to replace the head gasket,2. You may need to replace a piston ring. Thes are both pretty costly things to fix so I hope you can do it yourself
Old Jun 5, 2002 | 10:58 PM
Slammin 89 CRX SI's Avatar
Sounds like you need a new head gasket and possibly new rings, if its one of those possiblitys dont just replace one of the problems, replace both of the problems so you wont have to do it later down the road... LATER
Old Jun 6, 2002 | 10:11 AM
paulzy's Avatar
Default Re: somethin wrong with my hatch...dont know what it is. (Slammin 89 CRX SI)
swap....it's the easy way out
Old Jun 6, 2002 | 10:36 PM
wu tang's Avatar
Default Re: somethin wrong with my hatch...dont know what it is. (Slow_ass_4dr)
well slow *** does have a point...and wu tang forever. and it clicks when let out and in. so..what i need to do is..replace head gasket to see about the smoke and then wait to see if my clutch goes out. because with the clutch...when i first got my car..sometimes i would feel it sliping...but i started to drive slow and it stoped sliping...and then now its a sliping again and im still drive slow. ok..so i'll try to do that. i was thinking when i first got my hatch it pulled a code. and that code was for my fuel injectors. and 4 weeks agaio it went off. god knows how it went off...but whatever that was cool.
lxdriver
Jan 18, 2011 07:09 AM
Hatchd
Feb 4, 2006 03:05 PM
fUNk[LT]
Apr 9, 2005 03:10 AM
hatch_back
30
Mar 5, 2003 02:06 AM
NWPNOMORE
Jun 20, 2002 10:22 PM
